Why not rim screws instead of beadlocks? - JeepForum.com
post #1 of 10 Old 03-14-2013, 08:42 PM Thread Starter
MyKeyB
I was reading a thread on the zj forum and the subject of beadlocks came up. That got me to thinking about something I have not thought of for a few years. Why don't off road guy's run rim screws instead of beadlocks like drag guys do? It's cheap, easy, and should work. What am I missing? I'm sure if you had to take a tire off and then remount it, it would kinda suck. Other than that,why not?
Rust never sleeps...
MyKeyB is offline
post #2 of 10 Old 03-15-2013, 10:35 AM
mike_dippert
mike_dippert's Avatar
You mean screw the tire to the rim?
mike_dippert is offline
post #3 of 10 Old 03-15-2013, 11:01 AM Thread Starter
MyKeyB
Yeah.
http://www.mickeythompsontires.com/tech.php?bulletin=s4
I see in the link I posted they don't recommend useing rim screws with drag radials. Maybe a liability on the street or maybe because most drag slicks run tubes?
Rim screws:
http://www.summitracing.com/parts/mor-90100
MyKeyB is offline
post #4 of 10 Old 03-15-2013, 11:18 AM
mike_dippert
Complete shot in the dark...
Offroading puts lateral forces on the sidewalls. I see the tire ripping off of those at 5psi.
I'm sure they work great with radial forces to prevent spinning the rim when the tires hook up.
post #5 of 10 Old 03-15-2013, 11:28 AM
1320quick
Being a drag racer as well, I'm very familiar with rim screws. I use them on my drag slick but I glue my drag radials. The purpose of the rim screws is to keep the tire from rotating on the wheel as the car launches. If your running tubes in your slicks and the tire moves on the rim, it will rip the valve stem out as well. Most of the really fast drag cars use bead locks as they work better.
I'm not sure that using rim screws on a Jeep would accomplish keeping the tire on the wheel. It seems low air pressure and sidewall loads are what causes the tire to push off the the wheel and I don't think the screws would grip the bead good enough to hold it on. Also, some of the heads of the screws sticking out on the wheelside would probably get broken off playing in the rocks.
1320quick is offline
post #6 of 10 Old 03-15-2013, 11:52 AM Thread Starter
MyKeyB
Makes sense. I started thinking about lateral force after I posted the question. I only wheel lightly so it's not anything I would ever need or try, just something I have wondered about.
MyKeyB is offline
post #7 of 10 Old 03-15-2013, 07:18 PM
KKiowaTJ
The rocks would rip them out before you got a chance to try it. If they did make it, The first time i saw the wheel or use the sidewall its over.
Now if you took a fake lock like classic locks, Did alot of drilling and what not it might hold up. But with the $$ in all that, You could have a set of aero BL's for the price of a couple M/T wheels.
MOPAR!
KKiowaTJ is offline
post #8 of 10 Old 03-17-2013, 12:52 PM
texlurch
Also keep in mind that drag tires have a thicker bead area specifically to allow the screws. Most street DOT tires aren't near as thick.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #9 of 10 Old 01-10-2014, 05:27 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
old thread but.....
i have seen guys run screws offroad, instead of running the screws from the outside of the wheel inward, they run them upward on the inside of the bell of the wheel. this covers the issue of the lateral pressures presented while off roading. still not real beadlocks, but a heck of a lot cheaper. no personal experience but seems like it would work.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #10 of 10 Old 01-10-2014, 05:37 PM Thread Starter
MyKeyB
Now that seems like it would work. Thanks for the reply.
MyKeyB is offline
