Quantcast Why Bumpstops? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Why Bumpstops?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 02-19-2003, 10:00 PM   #1
91XJLimited
Why Bumpstops?
I haven't really looked into them, so I very well maybe thinking they are one thing, that they aren't. My perception of a "bump stop" is the rubber part, inside the coil spring (on an XJ). How do Extended bumpstops help articulation? It seems to me, that by extending the bumpstop, it would hit the axle earlier (than the stock bumpstop on a lifted XJ), and therefore limit how far the axle will articulate. Any insight is greatly appreciated.
91 XJ Limited - RE 5.5" XD, 32x9.50 TSL's, 4.0 HO, disconnects, other good stuff
94 ZJ 5.2 Limited - 6.5" Teraflex lift, Clayton Long Arms, disconnects, 37x12.50 SSR's, Hummer Beadlocks, and more good stuff
[SIZE=4][URL=http://www.geocities.com/lovaboy1599/My_Jeeps.html][color=red]MY JEEPS[/color][/URL][/size]
91XJLimited is offline   Reply With Quote
Old 02-19-2003, 10:22 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
A bumpstop limits upward travel of the axle. It's used to prevent the tire from stuffing too deeply into the wheelwell where pointy screws live,or to prevent the tires from rubbing or bumping the fender flares. So when the tire tries to move the axle up enough that the tire would rub where it shouldn't, the bumpstop will push the body up out of the way so the tire doesn't rub. Bumpstops need to be the right length, that is for sure. Too long and they inhibit articulation. Too short and the tires will rub where they shouldn't.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Old 02-20-2003, 12:17 AM   #3
cptn_mrgn78
Also too short of bumpstops can over compress your springs and cause sagging.
RIP: '97 TJ with 2in Teraflex with QD's. 32in AT's. Hi-lift jack, two 10in subs and a 500 watt amp. 150watt KC Daylighters. Avalanche Engineering Rocker Knockers.
New: '05 Unlimited
cptn_mrgn78 is offline   Reply With Quote
Old 02-20-2003, 06:49 PM   #4
91XJLimited
Thanks guys..cleared a lot up for me
Glock Forum
