Who rotates in their spare ? - Page 2 - JeepForum.com
post #16 of 33 Old 08-27-2013, 07:04 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I don't, because I don't carry a spare.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #17 of 33 Old 08-27-2013, 07:10 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by 2jhanna View Post
I was always under the impression that fronts wore quicker than rears ?
This is what I have always based this belief on. Pulled this off the 'net', so if must be true, right !!
"The engine, the heaviest single thing in a car, is usually at the front, so the front tires tend to carry more weight. The front tires also take care of all the steering duties. Plus, when you apply the brakes, the weight of the car shifts forward. Think about how often you brake while cornering, and you'll begin to understand why front tires almost always wear out faster than rear tires."
Nope, it all depends on your use.
My use is 2 wheel drive (rear axle) 90% of the time when I'm on the trail:
So, would that not mean more rear tire wear on my Jeep?
Two wheel drive until it gets difficult, then 4 wheel drive. The lockers come somewhere in between...
Knuckelhead is offline
post #18 of 33 Old 08-27-2013, 07:13 PM
Knuckelhead
AFSOC Retired
Swamps don't need spares?...
post #19 of 33 Old 08-27-2013, 07:13 PM
IH8PEPL
The gravel roads here murder my tire life so I dont rotate it in. When the current 4 are worn down and replaced I put the current spare into the new 4 tire group and put a new tire as the spare. Repeat a few years later.
Saves me from price shock, 4 tires are cheaper than 5... even though im doing it more often than if I did a 5 tire roatation. But the bill is $360 cheaper so I feel better about it.
IH8PEPL is offline
post #20 of 33 Old 08-27-2013, 07:19 PM
Headingout
on any vehicle I have with a full size spare, I rotate it in.
I find that tires go out of production quicker and quicker these days
and that leaves you with a mismatched spare tire.
also I don't trust a tire more than about 5 years old.
If You ain't Dutch, You ain't much.....
Headingout is offline
post #21 of 33 Old 08-27-2013, 07:19 PM
B52dude
I rotate all five! Hate to let that spare go to waste.
Originally Posted by Ripper3494 View Post
i think we should chase him around with yjs, its like being chased by zombies, slow, crippled but for some reason still scary as heck lol
Red Jeep Club #614
B52dude is offline
post #22 of 33 Old 08-27-2013, 07:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Nope! Just snorkels & lockers! LOL!!!
Max
Mean Max is offline
post #23 of 33 Old 08-27-2013, 07:37 PM
Knuckelhead
AFSOC Retired
Mud sucks!
Liquid sandpaper
"There is no situation that cannot be improved with a small but well-placed explosive."
I've done that a few times with some of my past neighbors...
post #24 of 33 Old 08-27-2013, 07:40 PM
Majnoon
I do. Got around 80,000 on MTR's will probably replace them soonish. Far from bald but not as off road worthy as new. Still plenty of tread for street. Spare is as worn as the others. Only way to go if you have a full size. 1/5 less wear. Get a year or more on your tires.
Majnoon is offline
post #25 of 33 Old 08-27-2013, 08:21 PM
J03_TJ
I wish I would have thought of this when I went to my current tire size. I bought the old style MTRs from Tire Rack and they had to get the last tire they had in my size from their warehouse back east. I knew they had been discontinued, but never rotated the spare in. Soon I think I might have the last unused old style MTR around. Kind of sad.
I've always had a nice thick tire cover over it, so not much UV exposure, just wonder how long it will be reliable.
J03_TJ is offline
post #26 of 33 Old 08-27-2013, 08:47 PM
JEK3
JEK3's Avatar
I used to rotate in my spare, until one front tire got the weird wear pattern where every third tread is higher. Once this starts, it just keeps getting worse. That tire is now my spare, and I just keep rotating around the four that are still round.
JEK3 is offline
post #27 of 33 Old 08-27-2013, 09:08 PM
wwch99tj
I do because I might not buy the same size or brand tire next time
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #28 of 33 Old 08-27-2013, 09:14 PM
pcwolf
I do every other oil change (6,000 miles) Spare to RF; RF to LR; LR to LF; LF to RR; RR to Spare
Wear the inboard/outboard treads evenly, changes the rotation direction, as others said I'll buy matched set of five at replacement because I am not married to any particular brand and I may want to go up/down wider/taller next time; my Club requires same-size spare for trail events.
-Phil
Man out standing in his field
o|||||||o
pcwolf is offline
post #29 of 33 Old 08-27-2013, 10:05 PM
JeepnBlake
I've had this happen on a select few of the OEM rubicon MTRS, it's always 1 in 5 or so.
Does anyone know if flipping the tire on the rim (IE flip the tire from black out to white out or vice versa) will help this problem or is the tire basically destined for a burn out contest?
I prefer the 5 tire rotation if it's optional. If you don't run a spare or never change tire size the 4 tire works just fine.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #30 of 33 Old 08-28-2013, 09:37 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
I have had a set of 35" and now my current tires are 37" old style MTRs, both sets did/do this. My solution is to move the tires on my driver side to the passenger side. Effectively doing the same as flipping the tire on the rim. The best defense for this is a better offense. So I try to rotate them around along with my full size spare, even though my spare stays in the garage. I bring it along for trail runs though.
Mail crawling.
MisfitSeven is offline
