Where to find tractor tires for jeeps - JeepForum.com
post #1 of 19 Old 03-20-2007, 05:29 PM Thread Starter
Elohim1
I want some skinny tractor tires for a 16" or 15" wheel , not over 35" tall.
Where can I find. I have searched with no luck yet.
Thanks in advance.
Elohim1 is offline
post #2 of 19 Old 03-20-2007, 05:36 PM
ptowntj
ptowntj's Avatar
I would call a local tractor supply store to verify...they will make for a dang bumpy ride though!
Edit, guess they do make them.
8 lug xj.
ptowntj is offline
post #3 of 19 Old 03-20-2007, 05:37 PM
rustzuk
1978 CJ7
I've bought them at local CO-OPS (feed mills). The name brands were American Farmer, and Goodyear made a set. American Farmer were by far the best and cheapest. Hopefully your axles and drivelines are upgraded. These tires are very aggressive and will point out any weak link in your drive train.
99 TJ sport auto / RE 4.5" SF / 35" Baja Claws / D30 aussie 4.10
/ 8.8 open 4.10
trail gear rock sliders / 9.5 ti
rustzuk is offline
post #4 of 19 Old 03-20-2007, 05:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Would a tire designed for a tractor be designed to hold together on the highway at sustained highway speeds?
Jerry Bransford is online now
post #5 of 19 Old 03-20-2007, 05:51 PM
KrazyGimp
1982 CJ5
Trust me, I grew up in an orchard and I have driven plenty of tractors to say that there is no way he would even get close to highway speed. You would not believe the amount of weight it takes to balance those things. Anything over about 25-30 and they just start to bounce so bad you barely can go any faster.
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
post #6 of 19 Old 03-20-2007, 07:16 PM
rustzuk
1978 CJ7
Mine were 33's and handled better on the road than my previous boggers. I had no problem going 45mph. There really stiff so you only need a few #'s of air. Couldn't be beat in deep mud.
/ 8.8 open 4.10
rustzuk is offline
post #7 of 19 Old 03-20-2007, 07:41 PM
nicolas-eric
do you mean such tires?
4" OME & 1" Spacer & LT Shocks 2" BL 1" MML JKS Discos JKS Rear Links OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 ARB Airlockers ARB Diff Covers 4.56 Gears SS Brake Lines
Warn Skids Genright Rock Slider Smittybilt Rock Crawler Rear Bumper Safari Snorkel OBA
12.000 lbs Winch Synthetic Winch Line 4x 130W Hellas 4x 200W Hellas @ Lightbar E-Fan
nicolas-eric is offline
post #8 of 19 Old 03-20-2007, 07:48 PM
bsruther
bsruther's Avatar
Is that your Mog?
bsruther is offline
post #9 of 19 Old 03-20-2007, 08:24 PM
nicolas-eric
no. a friend has such a mog.
and another friend has the mog axles with such tires under his CJ7.
post #10 of 19 Old 03-21-2007, 06:01 PM
fredrader
fredrader's Avatar
1947 CJ2A
That was because your tires were half full of liquid calcium for the weight..My Ford 8N did the same thing when we tried to pull it home to fast..Without the liquid in them they will not hop at higher speeds..They are not DOT approved though and are not legal to run on the road.(Except on tractors under 25mph)...
90XJ Limited 4x4,4.0 Auto,NP242
Rustys 4.5" lift D30/D35,3.55 gears
Denman Farmhand Tractor Tires 33x9.50x16
Work in progress
fredrader is offline
post #11 of 19 Old 03-21-2007, 11:20 PM
47cj-2a
tractor tires
my new holland runs 34mph so i guess it needs DOT approved tires
47cj-2a is offline
post #12 of 19 Old 03-22-2007, 08:59 PM
fredrader
fredrader's Avatar
1947 CJ2A
I found some today,Denman Farmhand R-1..9.50x16x33 $120ea..I bought 5 and I ordered 5 soft eights 16x7 with 4" backspacing $49ea..
They are for my cherokee..Elohim1 and me trimmed my fenders and I will be raising it up 4" or so but I figured I would get the tires and wheels on it first to see how high I will need to raise it..It is not going to be on any paved roads just trails and mud etc..
Work in progress
post #13 of 19 Old 03-22-2007, 09:07 PM
Lostj
Lostj's Avatar
where did you buy em from??
00'TJ
74'CJ5 For Sale
Lostj is offline
post #14 of 19 Old 03-22-2007, 09:12 PM
fredrader
fredrader's Avatar
1947 CJ2A
The Tires @ Gateway Tire Co. They have locations all over the U.S.
The Soft Eights @ Quadratec..
Work in progress
post #15 of 19 Old 03-22-2007, 09:24 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I am missing something? Why run tractor tires?
2013 FR-S
BlaineWasHere is offline
Tractor tires ArrizX Tires & Wheels 54 11-15-2013 10:48 AM
An odd tire site that I tripped over... lots of "tractor tires" Bennettj13 Tires & Wheels 1 01-22-2010 01:34 PM
tractor tires for 15" rim? JGriff99xj Tires & Wheels 2 10-20-2009 10:17 PM
lookin for tractor tires??? thickone Tires & Wheels 2 11-29-2008 04:44 PM
Tractor Tires who uses them??? Would they tear up my AXLES??? jeepcj-7 Tires & Wheels 11 03-30-2008 06:18 PM
