Wheels Spinning inside tire. - JeepForum.com
post #1 of 2 Old 09-24-2013, 03:31 PM Thread Starter
underpowered
Bouncin' on a Budget
underpowered's Avatar
i know beadlocks is the real answer for this question, and they are in the plans just not at the moment.
I am having issues of spinning the wheel inside my tires when aired down, would a bead sealer help with this issue or is there another trick to get it to stop?
i started out wheeling at 8PSI, then bumped up to 12 to try and stop it. anytime i get in a bind with all the weight on the rear of the vehicle i can't go anywhere because the tires are not spinning.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #2 of 2 Old 09-27-2013, 08:21 PM
rjbruzan
I air down to 4 PSI at the Dunes and the tires spin on the rims also. A friend tried RTV and bead sealer with poor results. He had 12" then 10" wheels. This is with BFG all Terrains and my GY MTRs. Those Swampers you run are hard as a rock so they have even less grip to the wheel.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
