Wheel weights... MT vs. ProComp - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Wheel weights... MT vs. ProComp
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 09-25-2006, 04:46 PM   #1
PDX-TJ
I am debating between MT Classic II and Procomp 1069.
The MTs are listed at 21 lbs. each (16x8)
The Procomps are listed at 30 lbs. each (16x8)
Anybody know why that is?? Can that even be correct? I got the info. of their respective web sites. I wonder why the Procomps are 9 lbs. heavier. They look exactly the same.
2012 Jeep Grand Cherokee Limited
Mineral Gray / Black
5.7L Hemi
ORA2
PDX-TJ is offline   Reply With Quote
Unread 09-25-2006, 08:16 PM   #2
Bryan H
Not sure about the 16's, the 15's have about .5" of difference in BS. That shouldn't affect the weight, but if you haven't already done so, you might check the 16's. That might be more of a deciding factor than the weight (I don't see how the ProComp could weigh nearly 50% more).
Bryan H is offline   Reply With Quote
Unread 09-25-2006, 08:26 PM   #3
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
Get the lighter ones. 21lbs sounds right. My aluminum 16x7's are are 18lbs per
2013 FR-S
BlaineWasHere is offline   Reply With Quote
Unread 09-25-2006, 08:29 PM   #4
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
The only problem is the lighter ones have 3.2 ish BS where the heavier ones have 3.75 BS. so it all depends on if you mind the extra BS or not.
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Wilmington weekly 4x4 meet
Jakemd98 is offline   Reply With Quote
Unread 09-25-2006, 09:31 PM   #5
BlaineWasHere
BecauseRacecar
Unless you have a decent amount of lift with large tires 3.2 will stick out really far.
I run 3.5" of BS and that is almost to much.
2013 FR-S
Unread 09-25-2006, 10:56 PM   #6
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
MT's insufficient backspacing has always kept me from buying their wheels, there's just not enough for me. For that reason alone, I'd go with the 1069 which is a decent quality wheel. I'll rag on the MT reps again at this coming 4x4 Expo in Pomona Calif. next month about their lack of backspacing.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 09-26-2006, 03:33 AM   #7
mgaspard
Please do. I sure would like a set of 15x8 M/T's with a 4.5" BS.
mgaspard is offline   Reply With Quote
