Wheel Spacers! - JeepForum.com
post #1 of 5 Old 06-19-2013, 08:13 PM Thread Starter
KTM31
Wheel Spacers!
Looking to add 1" wheel spacers to my 08 4door. I like the look and wondering if anyone has experience with them. Running a 4" lift with 35 General Grabbers.
Fight On! KTM
KTM31 is offline
post #2 of 5 Old 06-20-2013, 08:37 AM
biffgnar
biffgnar's Avatar
Buy a quality pair (e.g. Spidertrax) not cheapo Ebay special. Follow install instructions carefully. All will be fine. We run them on my college age daughter's XJ and I wouldn't want her driving back and forth to college with them if I wasn't comfortable.
Romney in 2020!
biffgnar is offline
post #3 of 5 Old 06-21-2013, 10:55 AM
bgredjeep
1987 YJ Wrangler
I've run a couple sets from ebay over the years with no issues. Currently only have them on the rear axle (1.25" I think). At one point I ran 1" in front and 2" in rear for a year or 2. As long and you install them properly and make sure they stay tight it should be fine.
bgredjeep is offline
post #4 of 5 Old 06-26-2013, 12:24 PM
Mr_Ranger
1978 CJ5
There are alternatives, if you're not fond on your rims. Places like 4wd.com can get steel rims with lower backspacing (like 2.5"), which will accomplish the same thing without the headaches from dealing with spacers.
Mr_Ranger is offline
post #5 of 5 Old 06-26-2013, 01:59 PM
mike_dippert
mike_dippert's Avatar
Wheel studs are 1.25" long. You'll have to cut off the extra so you wheel will fit snug against the spacer. Once you do that, you may not be able to go back without replacing all 20 studs.
You need a minimum of 1/2" thread engagement, but 3/4" wouldn't hurt.
mike_dippert is offline
