wheel spacer woes - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > wheel spacer woes
RuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-06-2010, 04:09 PM   #1
claytonandson
claytonandson's Avatar
wheel spacer woes
has anyone ever had a shop refuse to balance wheels or do a brake job because you had wheel spacer's ?? do you think its a ligitimate gripe??
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline   Reply With Quote
Unread 01-06-2010, 04:13 PM   #2
IRserge
I've never used wheel spacers but I'm a technician by trade. The only reason I can think of is if he didn't install the spacers correctly your wheels would fall off while driving. It's just a risk he wasn't willing to be liable for.
IRserge is offline   Reply With Quote
Unread 01-06-2010, 04:29 PM   #3
flatlander757
Eh it's semi reasonable from a liability standpoint... that is the shop's choice.
I wouldn't turn away business though... I would just note on the repair order that the vehicle had wheel spacers and advised the customer that it is not recommended(whether that matters or not... it's a CYOA sort of deal).
My $0.02
Edit: do the brake job yourself(it is NOT hard) and just take the wheels/tires to them off the Jeep to be balanced. Save on cost too since they don't need to uninstall or reinstall the wheels.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote
Unread 01-06-2010, 04:37 PM   #4
99TJSahara
My $0.02
x2 bring the tires of the jeep, saves you a couple of bucks.
I've never been refused for anything because of wheel spacers.
-Joey
99 Wrangler Sport
04 Grand Cherokee Overland
99 Wrangler Sahara-sold
99TJSahara is offline   Reply With Quote
Unread 01-06-2010, 08:12 PM   #5
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
yup, thats why i sold my wheel spacers and went to wheels with less backspacing. got tired of having to pull my spacers just to get the tires balanced.
Unlimited04 is offline   Reply With Quote
Unread 01-06-2010, 09:34 PM   #6
DBLJ
DBLJ's Avatar
My local place will do anything as long as its safe. I asked them specifically about this and they said they would.
Buy my welder. http://www.jeepforum.com/forum/f94/l...75-hd-1399807/
DBLJ is offline   Reply With Quote
Unread 01-06-2010, 10:11 PM   #7
tjkj2002
2002 KJ Liberty
As a automotive technician that has worked in the field for 13+ years I would never touch a vehicle that has wheel spacers on a job that required the wheels to be removed.It's juts simple liability from the stand point that there is more then a 50/50 chance that those wheel spacers will fail at some point.
tjkj2002 is offline   Reply With Quote
Unread 01-07-2010, 02:56 AM   #8
RogueSpear2023
Whether they will fail or not really depends on the vehicle, the quality of the spacers, and the person installing them, but this goes for just about any part. So for instance I would not put wheel spacers on a heavy duty truck the hauls or pulls heavy loads, but on a jeep you aren't going to be hauling anything heavy or putting 3000lbs in the back seat. And quality really depends on whether you buy quality $125 spacers or el-chepo $50 ones. And the install really depends on the competency of the installer and whether they use or know how to use a torque wrench, that said I didn't cheap out and bought wheels with the proper back spacing.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Unread 01-07-2010, 07:08 AM   #9
mdm
Farm Wheeler
...there is more then a 50/50 chance that those wheel spacers will fail at some point.
BS! What are you basing this on? I've used spacers on a few vehicles and put many miles on them. I've got around 50,000 miles on the set that are on my current rig. When does my 50/50 chance jump in for me? I've had tires shred, wheels bend, wheel bearings fail, brakes fail, distributor drives break, pistons break, oil pumps fail, valves stick, water pumps fail, power steering pumps wear out, power steering pressure lines blow, upholstery wear out, fuel pumps give up,... I've never had a spacer fail. What am I doing wrong?
As others have said, some shops look at it as a liability issue and don't want to touch them. Some tire shops won't install a tire on a vehicle that is not a stock size. I've heard of at least one shop that wouldn't put 31" tires on a TJ even though the Rubicon model came with what is the metric equivalent of a 31" tire.
There’s a 100% chance that I’ll die at some point. I guess I’ll just give it up and do it today – No encouragement please!
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote
Unread 01-07-2010, 10:53 AM   #10
tjkj2002
2002 KJ Liberty
You may actually have common sense to check the torque on the spacers often while most other will not.I'm also referring to those 3/16"-7/16" spacers that are to thin to have there own studs in them and those are very common with the people running 22"+ wheels on there cars and fail to install longer wheel studs,those types are just plain dangerous.
Unread 01-07-2010, 11:22 AM   #11
IslandTJ
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
I needed to take the Jeep in to my tire shop to get the tires rebalanced and rotated. While waiting, the tire manager was making small talk about the Jeep and thought I was running aftermarket wheels. I replied I was running stock wheels and he said it was unlikely, as they installed 33" tires when I first purchased the tires. The manager asked me if I had any rubbing issues and I said I didn't, but it was due to my 1.25" wheel spacers.
Immediately the manager said, “We don't work on vehicles with spacers due to liability issues” and notified me that he was going to stop all work on the Jeep and release the vehicle to me in the same condition it came in. Shortly thereafter, the manager stepped out to the service bay to tell his employees to stop all work.
After a couple of minutes, the manager came back inside to the customer waiting area and told me that there was no problem after all, and they would continue with the balancing and rotation. I asked why the change in position and the manager explained to me that I, in fact had "wheel adapters" on the Jeep and not "spacers". The shop had no problem/issues with “wheel adapters”.
I asked what the difference was and the manager told me that spacers were just like giant washers that fit in between the wheel and mounting point on the axles, the wider the spacer, the less threads used for latching the wheel lugs. As a result, this would place negative stress on the lugs due to the smaller surface area used by the lugs. The manager proceed to inform me that I don't have the lug issue as the "wheel adapter" had studs to properly mount the wheel vs. a spacer without studs.
Semantics...
1998 TJ Moss [COLOR=darkgreen][B][SIZE=3]Green[/SIZE][/B][/COLOR] Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
Unread 01-07-2010, 03:01 PM   #12
KKiowaTJ
Its mainly pointed to wards the retards who run 24" wheels and have to run spacers. You have to go back and re-torque them, A jeeper would understand that before they enter the shop, The rest of the public are oblivious to that fact and drive off and forget. If you do it for one, You do it for all. Most would rather not mess with it. But like said, Just explain they are adapters and not spacers.
Couple TJ's and a XJ
KKiowaTJ is offline   Reply With Quote
Unread 01-07-2010, 05:20 PM   #13
AdamSeven
1987 YJ Wrangler
have worked at shops before
taking the tires off and bringing them there will not decrease the price of balancing
that WOULD make since but it doesnt happen in a real shop.
maybe at indie shops but not dealers or a major chain. I have had to sign a paper saying all kinds or stupid **** like they arent responsible if my car starts by its self due to my remote start... or they wouldnt align my truck because i powder coated my rims black and didnt want to scratch them for an alignment... depends on the owner i guess so ask for a waver or however you spell it
as for the brakes
diy. pads and rotors can run you the same as just a pad slap at a shop.
AdamSeven is offline   Reply With Quote
