wheel size - JeepForum.com
post #1 of 11 Old 06-05-2013, 10:16 PM Thread Starter
plumber1
wheel size
why is every alum. wheel I look for have 4.5 backspacing. Eveyone says look for 3-3/4", but I am not having much luck
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #2 of 11 Old 06-06-2013, 12:08 AM
SlackJaw
baby jeep
SlackJaw's Avatar
You are not looking at 15" rims?
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #3 of 11 Old 06-06-2013, 12:47 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
What size tire will you be mounting on them? Depending on the tire width, 4.5" might be a very desirable amount of backspacing.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 11 Old 06-06-2013, 07:59 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Every aluminum wheel I've ever looked at had 3.75-4.5" backspacing.
TheBoogieman is offline
post #5 of 11 Old 06-06-2013, 10:28 AM Thread Starter
plumber1
I am looking at 16" 35x12.50 considering 15" but would like to keep my options open about Vanco brake kits in the future, hence the 16" and 17" are even more $$$$
plumber1 is offline
post #6 of 11 Old 06-06-2013, 10:30 AM Thread Starter
plumber1
It seams like the more I read the worse it gets, most say look for a 3.75 BS but I do not find many with that BS most are 4.5 so if this is not an issue I will go with the 4.5.
plumber1 is offline
post #7 of 11 Old 06-06-2013, 10:35 AM
Ironhead
one of the reasons i went with the dc-2's
16" rim and 4" bs. i have an AR up front, that saves some room, and i added a washer to each steering stop. there isnt much that i found in a 16" rim and 17s get pricey really fast
Ironhead is offline
post #8 of 11 Old 06-06-2013, 10:55 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I'd go with 17s instead of 16s.
16s are becoming less popular.
Wheelin98TJ is offline
post #9 of 11 Old 06-06-2013, 12:32 PM Thread Starter
plumber1
Are you saying that the AR allows for more room, because I am installing the AR. What are dc-2s ?
plumber1 is offline
post #10 of 11 Old 06-06-2013, 12:33 PM Thread Starter
plumber1
Yea I know but 17's are $$$
plumber1 is offline
post #11 of 11 Old 06-06-2013, 03:12 PM
Ironhead
Ya, probably about 2" closer to the frame than the stock sway bar. Dc-2 is a dick cepek rim. Pretty cheap for a 16" alloy and have 4" bs
Ironhead is offline
