Wheel bearing - JeepForum.com
post #1 of 4 Old 03-15-2013, 09:54 PM Thread Starter
scubaluke
Wheel bearing
Hi can anyone tell me if replacing a front left wheel bearing is hard on a 96 xj cherokee and what size socket I will need to remove the hub
scubaluke is offline
post #2 of 4 Old 03-15-2013, 10:10 PM
1995_XJ
1995 XJ Cherokee
Should'nt be too hard, and the axle nut is a 36mm
1995 Cherokee Sport
1995_XJ is offline
post #3 of 4 Old 03-15-2013, 10:14 PM Thread Starter
scubaluke
Are there any springs and washers I have to worry about putting in the rite places?
post #4 of 4 Old 03-16-2013, 09:30 AM
KKiowaTJ
36mm hub nut as mentioned, Crank back down to 175 ft/lbs IIRC when done.
Three 6 point IIRC bolt hold the bearing on from the back of the knuckle. I cant remember the tq spec's for it off hand. No extra tools needed but a 19mm for lug nuts and 13mm, 12mm, maybe a 10mm 3/8 sockets.
To get the shaft out of the bearing there are a million ways, IMO do a search for MrBlane's nut/bolt tool that will press it right out with a turn of the wheel. Or the BFH and a pry bar works too. Good luck
MOPAR!
KKiowaTJ is offline
