wheel advice with 3.5" lift kit. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > wheel advice with 3.5" lift kit.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitClayton Off Road - Come see us at these events!
Unread 03-27-2014, 12:13 PM   #1
Dflores0625
I recently got a 2012 JK with stock Rubicon wheels an tires... 255/75/17...does anyone know if does stock wheels will work with a 3.5" lift kit?
Dflores0625 is offline   Reply With Quote
Unread 03-27-2014, 01:01 PM   #2
Dflores0625
Help with wheel and lift advice
Unread 03-27-2014, 03:02 PM   #3
Mtnduey
no reason the stock wheels & tires wouldn't work with a 3.5" lift kit. You will have some extra space using the stock wheels & tires but you can fill some of the space with careful tire choice.
IMO, do the suspension work first followed by body armor/bumper/winch and then pick your tires (and wheels if you so choose) afterwards. The 17" wheel gives you quite a few solid options depending on how big you want to go.
-D2
Mtnduey is offline   Reply With Quote
Unread 03-27-2014, 03:22 PM   #4
Dflores0625
I was thinking the same Mtnduey, I'm wondering if I would have to buy wheel spacers due to the lift kit. Most likely I bet.
Unread 03-31-2014, 11:37 AM   #5
rochelle426
Stock wheels should work with the lift. Some rims naturally kick out the wheels a little more too, so I don't think spacers would be necessary.
rochelle426 is offline   Reply With Quote
Unread 04-01-2014, 05:55 AM   #6
tyvanwie
tyvanwie's Avatar
Why do you think that?
MY BUILD THREAD
MY FITNESS LOG/TRANSFORMATION
JK AND TJ PARTS FOR SALE
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is online now   Reply With Quote
Unread 04-02-2014, 04:59 PM   #7
Dflores0625
well finding out that Makes sense that wheel spacers needed when going with bigger tires, the wheels I'm running now are the stock Rubicon tires and wheels which are I believe 32" R17 which would be ok to run on for now and would clear when turning the wheels. I'm planning on getting 35's on it eventually and then I know I would need wheel spacers for sure.
Unread 04-02-2014, 05:13 PM   #8
tyvanwie
tyvanwie's Avatar
That makes sense for when you get the 35s because they will be wider. But you do not need them for stock tires.
MY BUILD THREAD
