Whats my wheel bolt pattern & lug nut size? - Page 2 - JeepForum.com
post #16 of 32 Old 10-25-2010, 09:25 AM
Ggg
Lug nuts:
All 6-lug full size Jeeps = 7/16-RH
All 5-lug Jeeps = 1/2-RH
If I missed anything let me know...
Just letting you know not all 5 lug Jeeps used 1/2"RH threads.
Willys CJ and I believe the Kaiser Frasier CJ's had RH and LH lugs depending on left or right side of the vehicle. I have seen many with broken off lug studs from Willys newbies trying to remove the LH lugs the wrong way.
Ggg is offline
post #17 of 32 Old 10-25-2010, 05:07 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if you can provide what year & model has what lug type, I'll update the thread.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #18 of 32 Old 10-25-2010, 09:59 PM
Ggg
Well, I don't know if you really need models or years as all Willys and Kaiser Frasier MA through CJ5, truck, and trailer models had left handed lugs on the left side from 1941 up to 1969. But if you really want the models and years I can list them, but it will be a long list. Many of these have been converted to RH threads over the years but from the factory in Toledo they came with LH.
I hope that helps.
Ggg is offline
post #19 of 32 Old 06-22-2011, 09:39 AM Thread Starter
Unlimited04
Updated to include the following link from the 4-Wheel Parts website:
http://www.4wheelparts.com/downloads...lt_pattern.pdf
Useful Write-Ups:
Funny:
post #20 of 32 Old 04-06-2012, 07:36 PM
OrphanAnnie
Good to know!
OrphanAnnie is offline
post #21 of 32 Old 05-09-2012, 10:53 AM
JeepSteerables
Lugs Nuts & Bolt Patterns
I have one for you guys! I have a set of 17" Black Steel Wheels with 33" MTZ Run Flats on them. They are 5 Lug, but the pattern is kinda squirly - they won't fit my '97 TJ as the bolt to bolt is longer on the wheels than the Jeep. I also have a 1970 CJ Kaiser (For Sale...) - but they won't fit that either.
I understand there may be a spacer I can buy to put these on my TJ? Problem is these rims may be metric as they were from a Right Side Steer J8 (Military) built in Egypt....
Any advice????
Matthew.Drake@theupc.com
910-358-4131
1969 Kaiser Jeep CJ - Desert Tan, 1993 Jeep YJ - Gold Tan, 2011 Jeep JK - Desert Tan, 1997 TJ - White (Right Side Steer)
JeepSteerables is offline
post #22 of 32 Old 05-09-2012, 10:56 AM
stu132u
Any advice????
910-358-4131
Maybe 5 on 5 like the JK's - you could always take them to a tire shop that sells rims and they should be able to measure them for you.
stu132u is offline
post #23 of 32 Old 09-28-2012, 09:54 AM
RACN61
Looking for info and pics of factory jeep wheels does the forum have a and i use the term loosly "wheel decoder"??????
RACN61 is offline
post #24 of 32 Old 10-05-2012, 11:37 AM
bluei6
you should be able to google search it.
bluei6 is offline
post #25 of 32 Old 03-13-2014, 03:09 PM
ERIK2014
2014 XJ Cherokee
Help me
Can anyone tell me the lug size for my 2014 grand cherokee with the 20" overlander wheel package (20" aluminum.) i am painting the wheel to match the same color as the jeep (dark forest green) and i cannot find black aftermarket lugs to fit the factory wheels. The dealership only has the chrome and i need some help to find hte proper lug.
ERIK2014 is offline
post #26 of 32 Old 11-10-2014, 02:06 PM
joejoe1068
I have a 2011 Jeep Liberty with 5 on 4.5 , with 20 inch rims.
I want to switch to Jeep JK 5 0n 5 , 18 inch rims.
What is needed?
joejoe1068 is offline
post #27 of 32 Old 12-16-2014, 09:26 PM
kuker
What is needed?
Easy way is to get adapting spacers, about $80 an axle
kuker is offline
post #28 of 32 Old 02-14-2015, 08:27 PM
03RubiconAL
I want to add these wheels
http://www.performanceplustire.com/b...atte-black-rim
But I dont want to rub on suspension. I'm not worried about the wheels sticking out--will add wider fenders. So, go with the 4.89 backspacing & 10mm offset or go with 5.88 backspacing & 35mm offset?
Just Empty Every Pocket
treadlightly.org
03RubiconAL is offline
post #29 of 32 Old 08-26-2015, 06:32 PM
newtobe
newtobe is offline
post #30 of 32 Old 11-22-2015, 09:40 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Lug nuts:
what length are the oem studs?
One site is selling for the front hub studs and don't have anything for the rear.
Are front and rear different?
Do the new studs have to be pressed in? Or will a heavy hammer do the job?
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
bolt pattern , bp , lug nut size , lug nuts
Anybody know what the bolt pattern and backspacing is on this wheel? 94YJEEPER Tires & Wheels 6 06-15-2009 12:36 PM
Wheel Bolt Pattern zener6 Tires & Wheels 1 11-29-2008 01:37 PM
A little confused (bolt pattern and wheel width) LuCk3e87 Tires & Wheels 4 09-14-2008 12:53 PM
Wheel Model Bolt Pattern Question Rickster49426 Tires & Wheels 2 04-23-2008 07:53 AM
00 Tj 5x4.5" wheel bolt pattern verify? Blk2kTj Tires & Wheels 2 02-27-2007 10:10 PM
