Whats the difference between P225/70R16 and P225/75R16 tires? - JeepForum.com
post #1 of 5 Old 02-12-2013, 08:51 AM Thread Starter
TJJeepJosh
I need to get new tires for my 01 Wrangler.
I found a nice used set of P225/75R16 tires.
Also found a new set of P225/70R16 tires.
Both are relatively the same price but whats the difference between the two? will either one fit my jeep?
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 5 Old 02-12-2013, 10:16 AM
mschi772
1997 XJ Cherokee
225/75R16 is about an inch larger in diameter than 225/70R16 (29.3" vs 28.4").
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #3 of 5 Old 02-12-2013, 11:10 AM
WXman
Both of those are midget sizes, so at least do the 75 height.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #4 of 5 Old 02-13-2013, 06:34 AM
wh1plash
Here's a great tool for you:
http://tire-size-conversion.com/tire-size-converter/
If you have a size like P225/75R16, that means:
P = Passenger, aka lighter load than LT (light truck)
225 = width of the tire in mm
70 = height of the tire is 70% of the width (75% of 225mm)
R16 = fits a 16" rim
So for those two tires, they both have the same width, but the 75 is going to be slightly taller than the 70.
Current: 1999 TJ Jurassic Park project
My build projects: brandoncrismon.com
wh1plash is offline
post #5 of 5 Old 02-13-2013, 01:56 PM Thread Starter
TJJeepJosh
Learn something everyday. Thanks for the help
help needed , tire size , tires
