Whats the diff between Body Lift and Suspension Lift? - JeepForum.com
post #1 of 8 Old 01-11-2005, 06:58 PM Thread Starter
loudog3114
Im looking for a cheap inch or so, what is better that wont make the ride any worse?
loudog3114 is offline
post #2 of 8 Old 01-11-2005, 07:12 PM
doublins
if all you need is one inch, the obvious choice is a 1" bodylift- installs in 45 min with hand tools in a parking lot, costs just $100, and will not affect vehicle safety/performance negatively at all.
However, if you're looking to get more, body lifts over 1" are not recommended as their safety in an accident is questionable to say the least. Anything over 1" requires a suspension lift.
For 2" of lift, look at Rubicon Express' Budget Boost kit, for about $250 or so, will give you a 2" suspension lift without sacrificing ride quality. Throw a 1" body lift on that for a grand total of $350 or so, and you have 3" of safe, cheap, effective lift.
-Chris
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
doublins is offline
post #3 of 8 Old 01-11-2005, 07:21 PM Thread Starter
loudog3114
I was thinking for some reason that body lifts were the spacers that go on top of the coils... now im thinking im wrong. Where exactly do the spacers go? Im a bit confused, I heard that the radiator fan hits if you use a 1" body lift... but arent the engine mounts on the body? Maybe im wrong and they are on the chassis? Either way, is there anything else that needs to be done if I do a 1" body lift (to prevent the fan from hitting for instance).
post #4 of 8 Old 01-12-2005, 10:14 AM
Av Native
The body lift is spacers that go between the body and the frame where the body mounts, If you do a body lift, you will either need to do a motor mount lift or remove and redrill your fan shroud to move it up with the body, the motor mounts are bolted to the frame so the motor mount lift stays bolted to the same place but the mount is one inch taller.
A budget boost is spacers that go between the spring and the mount to set the whole frame up two inches.. same thing as going with a longer spring but cheaper..
If you want to do the job correctly, do the motor mount lift with the body lift, that way if you do the BB you drive line angles will be better for less chance of vibes..
04 Silver TJ
4" rough country lift
1" currie MML/BL
JC fab rockers and 1" seat lift
33"BFG MT's
Nth degree adjustable upper arm
Nth degree lower arms
Power trax front locker
Av Native is offline
post #5 of 8 Old 01-12-2005, 12:57 PM
WVZJ
You can also get 1" Coil spacers to put on top of your coils instead of the body lift. For a few more bones you might as well get a 2" coil spacer. Either way I would go with the coil spacers over the body lift. I have never been a fan of body lifts.
98 ZJ 5.2, LA n Locked, 242 sye, 35's
87 MJ, 4.0, 8.8, 33's, oba
07 Ram 2500 5.9 ctd
WVZJ is offline
post #6 of 8 Old 01-12-2005, 01:43 PM
Joel77
But with coil spacer you MUST change your shocks because they will become short.
Joel
Joel77 is offline
post #7 of 8 Old 01-12-2005, 02:50 PM
WVZJ
Joel
You wouldn't have to change shocks with just 1" spacers, if you felt they weren't long enough you could add bump stop. Most shocks work within a range of 2-3". Not just one certain height.
07 Ram 2500 5.9 ctd
WVZJ is offline
post #8 of 8 Old 02-01-2005, 02:27 PM
Chrisca
Chrisca's Avatar
The bump stop doesn't extend the length of the shock. It still has the same amount of travel
The bump stop simply keeps the shocks from compressing too far.
This is helpful when you get bigger tires to keep them from rubbing the fenders or wheel well.
With a 1" lift, the original shock will simply be extended out 1 inch further than it normally is.
2004 Grand Cherokee Laredo
Chrisca is offline
Can I clear 32x11.5x15s with only a 2.5 suspension lift (no body lift) on my 2006 TJ? ddonjon General Jeep & Off-Road Equipment 3 04-21-2009 10:49 AM
Why is it bad to have a body lift and a suspension lift? XJKingJeezy General Jeep & Off-Road Equipment 21 03-17-2009 03:49 PM
Body Lift or Suspension Lift dmb0485 Tires & Wheels 3 02-21-2006 06:07 AM
Why body lift plus suspension lift? w^rl0rd Tires & Wheels 15 03-11-2005 02:48 PM
Body Lift with Suspension Lift?? RockinTJ Tires & Wheels 0 04-13-2001 12:45 PM
