What Tire Pressure on/off road??? - JeepForum.com
post #1 of 7 Old 10-14-2008, 07:13 AM Thread Starter
TJeep_1999
2015 JK Wrangler
What tire pressure should I be running with 31x10.5xR15 tires? What should I air them down to when going off road? Not sure that it matters, but I have a TJ. Thanks!
TJeep_1999 is offline
post #2 of 7 Old 10-14-2008, 07:24 AM
BlackBellamy
BlackBellamy's Avatar
Personally I ran those tires at 28-30 on road, 12-14 off. Search this forum for "chalk test" - your pressure will depend on comfort vs mpg vs tire wear so pick your own pressures.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #3 of 7 Old 10-14-2008, 08:26 AM
daveshan
Feeding the money pits
daveshan's Avatar
Testing them yourself (chalk test) is the only way to determine a good street pressure.
Tires vary in sidewall stiffness greatly and tread width/rim width make a difference also. My BFG ATs on 15x8" rims need 24psi +- on the street, the Maxxis Creepy Crawlers on 15x 10" rims run on the center lugs only at anything more than 16psi.
Off road a bit of experimentation will show you what works best. If you post tire brand and rim width someone may have a similar set and can give you a baseline.
Dave Shannon
Durango, CO
Gone but not forgotten
'56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr
daveshan is offline
post #4 of 7 Old 10-14-2008, 08:31 AM
JFranko
I guess I'm running mine a little high compared to everyone else, I'm running 32" bfg mts at 35 psi, and they wear pretty even
JFranko is offline
post #5 of 7 Old 10-14-2008, 09:17 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Can't say for on-raod pressure in a 10.5 but the chalk test works well. Off-road you need to go down to at least 12 to really get any benefit.
Whybu1 is offline
post #6 of 7 Old 10-14-2008, 09:26 AM Thread Starter
TJeep_1999
2015 JK Wrangler
I'm running 31 x 10.5 BFG ATs on 15x8" rims... Thanks for all the advice. I think I have a pretty good idea now. I always worry that I air down too much and will loose a bead. I think 12-15 and I should be fine. Thanks agian!
post #7 of 7 Old 10-14-2008, 10:50 AM
daveshan
daveshan's Avatar
Sounds about right, I used to run BFG ATs in the 33x10.5 size on Eagle 7" wide rims and ran 11-12psi on trails with no issues, 25psi was about right for street use.
Dave Shannon
Durango, CO
daveshan is offline
What is the correct street tire pressure and off-road pressure? JeepinYahoo Tires & Wheels 84 04-11-2013 06:52 PM
On Road Tire Pressure For 33ís? cvd Tires & Wheels 5 09-14-2008 01:42 PM
What tire pressure for on road, 31" BFG AT's truckin88 Tires & Wheels 1 05-23-2008 02:51 AM
Best Tire Pressure to Use On & Off Road AtlJeeper Tires & Wheels 4 10-15-2006 03:39 PM
Off Road Tire Pressure Scafone Tires & Wheels 4 01-09-2003 11:41 PM
