what size hmmm...? - JeepForum.com
View Poll Results: will 35" tires fit on my 3" lifted tj?
yes, as long as you don't go off road 1 25.00%
yes, but no crazy off roading 1 25.00%
no, do a 1" BL first 0 0%
NO! 2 50.00%
Voters: 4. You may not vote on this poll
post #1 of 2 Old 09-11-2010, 01:33 PM Thread Starter
Shinta
what size hmmm...?
so i have been looking on this site for about 2 day trying to find the answer to my question, but i havent had much luck yet. so here it is
i have a 99 TJ, 3"SL, dropped the transfer case 3/4". i am looking at some 15x10 wheels with 3.75" backspacing and i want to put 35x12.5 on them. also my jeep is an automatic.
i have heard that the 35's can rub on the fender, does this mean that they will rub the plastic on the outside or the actual metal? im not going to be going off road but if i do i will be putting a 1"BL on first.
so will this setup work? and if not what do i need to do to make it work.
Shinta is offline
post #2 of 2 Old 09-11-2010, 09:28 PM
KKiowaTJ
They will fit fine. I ran 35's on that amount for a year with off road time. I run 15x10" 3.75 BS and have never had a rubbing problem. They will allow you 100% turning radius with no rubbing on the LCA's. If you adjust your bump stops right it wont at full stuff.
But at 3" you are pretty much eliminating up travel but down is still good. I'm going to be replacing my 3" BL soon for a 1.25" BL and have no worries about rubbing and if it does, It will be plastic flair or tube so i could care less considering what i have purposely done to it. Its going to get rash anyways, To each his own, Good luck
MOPAR!
KKiowaTJ is offline
3" , 33 , 35 , tires , wheels
TJ RE 3.5 SF lift kit with what size OME or Bilstein 5100 shocks size.... will21190 General Jeep & Off-Road Equipment 0 07-31-2010 03:38 PM
Hmmm BFG's AT VS MT Toady Tires & Wheels 5 08-02-2008 06:53 AM
The TRUE Street Xj...hmmm tdogg55555 Street Jeep Forum 35 06-17-2008 05:30 PM
help with 17inch wheels/tire size/lift size spillz Tires & Wheels 0 02-15-2008 12:48 PM
hmmm mathomas3 Engines & Drivetrain 6 06-22-2006 12:11 AM
