What's the Difference Between... - JeepForum.com
post #1 of 4 Old 11-10-2005, 12:56 PM Thread Starter
Canuck262
A BB with an add-a-leaf and one with a shackle? Thanks in advance!
Cheers!
'86 CJ-7
Canuck262 is offline
post #2 of 4 Old 11-10-2005, 01:04 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I don't know leaf spring suspensions that well but one thing for sure, an add-a-leaf will sure make it ride a lot stiffer.
Getting
Jerry Bransford is online now
post #3 of 4 Old 11-10-2005, 03:30 PM
dynamite44
if your leaves are in bad shape, an add a leaf will provide a longer lasting lift than a shackle lift would. i made the mistake of putting shackles on the back of my XJ to try and boost the sagging rear end. the shackle just accelerated the negative arch of the leaves. now ive gotta spend like 150 for new springs, plus 60 or so for add a leafs to fix what i didn't do right the first time.
shackles are easy, 2 bolts in either side, but add a leafs are better if you care about your springs.
the very best way to do things is to replace the springs, but its hard to find budget-boost sized full leaf packs aside from those made by OME, and those are pretty expensive.
2000 XJ silverstone metallic.
dynamite44 is offline
post #4 of 4 Old 11-10-2005, 04:13 PM
TellyDSP
Poland and PPV!!!!
Cheers!
I mostly see BB referenced for TJ's as a puck placed on top of the coil. On an XJ, I'm going to assume the option is a coil spacer in front with an AAL(add-a-leaf) or a BB(Budget boost) with a shackle lift. The AAL will create a stiffer ride as mentioned. Your doing just as it sounds. Adding a shorter arched leaf to your pack. Helps add some arch and stiffness to your existing pack. A Shackle lift will replace your existing shackles with taller ones. If you're springs are sagged and shot, this will only creat the illusion of an improvment but you'll still need new springs. Taller shackles in the back arent as bad as the front. In the front they can affect your approach angles and handling.
IMO, if your springs are in decent shape, I would go with the shackles. As long as they're not too tall. Bout an 1 1/4 or so wqould be as high as I would go. You can always use them in conjunction with new springs if you ever decided to add lift springs. Same thing you can do wth the pucks. Then again opinions are like...
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
2.5L, YJ to TJ difference? psycopanther Engines & Drivetrain 4 04-22-2009 09:25 PM
Need to know the difference between PSC.............. OffCamberTJ Fabrication Shop 2 02-05-2007 10:30 AM
Wow what a difference with gas Psyker Fabrication Shop 1 11-20-2006 11:22 PM
is there really any difference?? drummerwookie General Jeep & Off-Road Equipment 2 10-18-2005 07:42 PM
how do you tell the difference 304/360 Notplayn Engines & Drivetrain 4 03-11-2004 05:35 PM
