what psi to inflate to?! - JeepForum.com
post #1 of 8 Old 05-25-2005, 09:16 AM Thread Starter
paroxysym
2007 WK
im getting bfg m/t's in a 31x10.50. what psi should i be at when im cruising aroundon the streets? i dont know if the tire place will inflate them right. usually they over-inflate them. what would you recommend?
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #2 of 8 Old 05-25-2005, 09:30 AM
denverd0n
Do a search for chalk test.
denverd0n is offline
post #3 of 8 Old 05-27-2005, 11:09 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
31 to 33 psi is pretty good for that size tire.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #4 of 8 Old 05-28-2005, 08:36 AM
hoosier724
hoosier724's Avatar
what's wrong with the psi that's printed on the tire?
'03 TJ Sport,Light Tan Metallic,, Superlift 4" with BFG 33x12.5x15
Honk if you love Jesus...text while driving if you want to meet him!
hoosier724 is offline
post #5 of 8 Old 05-28-2005, 09:53 AM
fisher446
thats the max pressure they should ever be run at. (i think).......
Green dented and scratched 95 Cherokee Country.
RC 4.5" lift cragar soft 8's with 4" BS
33x12.50x15 Mud Dawgs
MMM MMM I love me some mud.....
fisher446 is offline
post #6 of 8 Old 05-28-2005, 10:02 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
it's the MAX pressure, and only if you have the MAX weight on them...
my 32x11.50's are rated for MAX 2535lbs @ 50PSI
my 36x13.50's are rated for MAX 2810 lbs @ 30PSI
multiply those by four (number of tires) and the Jeep would need to weigh 10140lbs or 11240lbs to need the pressure listed...
since your Jeep weighs less than half of that, you definitely don't need that much air...
I have my 36's at around 20PSI for the road, and my 32's are just below 30PSI...
if you'll look at the decal that's probably in your driver's side door jamb, you'll see the recommended pressure for the stock tires...and it's WELL below the MAX pressure on the sidewall...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #7 of 8 Old 05-28-2005, 10:43 AM
Jerry Bransford
Administrator
Simply put, that maximum pressure molded onto a tire's sidewall is only for use when the tire is supporting its maximum designed for allowable weight. Since tires seldom (and never in a Jeep's case) support their maximum allowed weight, they should seldom (never in a Jeep's case) be inflated to that pressure.
Getting
post #8 of 8 Old 06-07-2005, 10:34 AM Thread Starter
paroxysym
2007 WK
im currently running my mud-terrains at 28 psi, maybe a hair above that. is that fine? i didnt do the chalk test. all i know is its better than the 36 psi that NTB inflated them to.
OEM+
really? Inflate a tire with wd-40? 2dog Tires & Wheels 16 06-02-2009 08:45 PM
