what offset wheels do i need - JeepForum.com
post #1 of 5 Old 10-27-2001, 07:13 PM Thread Starter
evilpsych
evilpsych's Avatar
oh.. i want to run 31x10.50's is the stock wheel ok on a '93 YJ? or do i need to get a diff wheel with less of an offset..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 5 Old 10-29-2001, 06:44 PM
osburn
osburn's Avatar
They'll work fine on your stock rims. Your tires might rub your springs a little in tight turns. You can adjust your steering stops a little or just back off a little when ya feel/hear the tires rubbing the springs.
Matt Osburn
Score 1032
osburn is offline
post #3 of 5 Old 10-29-2001, 08:10 PM
igofshn
Locked @ both ends
igofshn's Avatar
31's will not fit under a YJ unless you have a lift. It doesn't matter what your backspacing is. THEY WILL RUB.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 5 Old 10-29-2001, 08:23 PM
osburn
osburn's Avatar
Oh take your TJ butt on outta here! Hey, I'm kidding don't get flustered. The fellow already has been asking the lift questions in the YJ forum. He knows, he just asked a tire question in the tire forum is all. And you can put 31s on a YJ without lift and not rub by the way. But it's a YJ secret. You gotta know the handshake or we won't tell ya.
Matt Osburn
Score 1032
osburn is offline
post #5 of 5 Old 10-29-2001, 08:42 PM Thread Starter
evilpsych
evilpsych's Avatar
hehehe yeah..
i plan on doing a 1" body lift.. yeah i know it's a compromise, but i'm still a newbie and i lack $$$ at the moment.. plus it's generally required if you're going to run 33's - 35's.. figure i'll do a SOA conversion and CV driveshafts and gears later.. at the moment.. i've just been donated some slightly used 235/75R15's by my dad and figure those are better than the street treads i have now.. oh.. the new U-joints all around made a HUGE difference in how my YJ rode, shifted, accelerated..
A
offset of stock CJ7 wheels desmolift Tires & Wheels 0 08-11-2008 08:19 AM
what offset do i need??? mike4089 Tires & Wheels 11 01-09-2008 10:58 PM
Offset Wheels Duck Dodgers Tires & Wheels 2 10-29-2007 09:04 AM
Offset ebraunschweiler Tires & Wheels 1 04-11-2006 04:46 PM
Rim offset FOoLieo Tires & Wheels 3 03-30-2005 07:36 PM
