What does a lift kit install cost? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > What does a lift kit install cost?
XJ guys, clock your transfer case!D.i.y. Ford 8.8 tj,xj,yjTrek Armor Seat Covers now at JeepHut
Unread 06-29-2007, 04:09 PM   #1
pbskidz
I'm thinking about getting a 2 inch lift sometime in the future for my TJ and I have no idea how expensive they are to install. I'm planning on maybe getting that 2 inch, $250 dollar skyjacker lift.
pbskidz is offline   Reply With Quote
Unread 06-29-2007, 05:54 PM   #2
nicolas-eric
installing it is very easy. do it with a friend on your own and save the money for the installation for some other jeep parts.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote
Unread 06-29-2007, 05:59 PM   #3
XJK
The Guru of Nothing
XJK's Avatar
X2, just DIY. Most shops will charge 80-110$ per hour and the lift will take at least 3 hours (bare minimum). You do the math.
just grab a buddy, and get to work on it. Its really not as bad as you may think it is.
-Kyle
XJK is offline   Reply With Quote
Unread 06-29-2007, 06:01 PM   #4
nicolas-eric
i needed only 3 hours for installing the skyjacker budget boost 2" lift. and that was the first time i installed something on a car.
Unread 06-29-2007, 06:23 PM   #5
krykrykrynunit
if you know any good welders, have them do a custom lift, but might cost more
better though
krykrykrynunit is offline   Reply With Quote
Unread 06-29-2007, 09:19 PM   #6
chutta
You have to get self sufficient on this or the habit will break you. Don't over invest in tools such as overkill on a 60 gallon compressor etc. It gets you familiar with everything and gives confidence in replacing broken stuff down the road or trail, which eventually is going to happen.
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline   Reply With Quote
Unread 06-30-2007, 06:50 AM   #7
hazmat
where are you at in delaware? I'll give you a hand.
hazmat is offline   Reply With Quote
Unread 06-30-2007, 10:26 AM   #8
pbskidz
Alright well it sounds like I should just install it myself, what kind of tools am I going to need? I do work at a car lot and there is an auto repair and installation place right beside it so I could get a good deal, but it would still probably be out of my range. I'm in Lewes DE.
Unread 06-30-2007, 05:36 PM   #9
Oldjeepman
install
all you will need is a floor jack and some tall jack stands and hand tools and a pry bar for stubborn coils and a buddy,really not to hard to do make sure you soak all bolts a couple days before hand
Oldjeepman is offline   Reply With Quote
Unread 06-30-2007, 06:22 PM   #10
jzmtl
better though
How does a welder give you a better than what you can buy lift?
The funny thing about this signature is that by the time you realize it doesn't say anything, it's too late for you to stop reading it.
User CP > Options > Uncheck "Show Signatures"
jzmtl is offline   Reply With Quote
