Quantcast What causes power loss? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > What causes power loss?
Old 12-12-2007, 08:54 AM   #1
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
It is a fact that going from stock tires to larger tires results in a loss of power (without regearing). My questions is, what is the reason for this? This is an issue of physics. Below are some suggested reasons:
Weight of the tire
Diameter of the tire
Rolling resistance (contact surface area)
Tire mass (weight is not the same thing as mass)
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/
dogbluedrummer is offline   Reply With Quote
Old 12-12-2007, 10:00 AM   #2
Chris_
Are you just making idle chit-chat?
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline   Reply With Quote
Old 12-12-2007, 01:53 PM   #3
dogbluedrummer
Trust me....
Not idle chit-chat. I want to understand the physics behind the fact.
My build threadhttp://www.jeepforum.com/forum/showthread.php?t=528892
Old 12-12-2007, 02:42 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
A larger diameter tire also has a longer radius, which equates to the tire having more leverage (moment/arm) against the drivetrain which means the engine must develop more power to overcome that increased leverage.
Plus a larger tire can be thought of as a larger gear against a smaller gear (the ground) that requires more force to turn (a higher ratio).
Then there's the larger tire's increased rolling resistance, its increased weight, increased enertia, and its increased mass that the engine must work harder in order to overcome. Also a factor is that taller tires cause a Jeep to sit higher up in the windstream for higher wind resistance that must also be overcome.
Those will do for starters, right?
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 12-12-2007, 02:53 PM   #5
hoseclamp
This is all wrong, power loss occurs because of increased weight of the heavier muffler bearings which are required when installing bigger rubber.
'04 Rube
JEEPS ARE NOT CARS, STOP CALLING YOUR JEEP A CAR!!!!!!!!
hoseclamp is offline   Reply With Quote
Glock Forum
