What all do i need if changing gears - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > What all do i need if changing gears
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 09-18-2001, 10:28 PM   #1
yjman
im going to put 4.56 gears in my dana 30 and rear 35 what all do i need to change out the gears
yjman is offline   Reply With Quote
Unread 09-19-2001, 11:10 AM   #2
osburn
Are you talking about doing it yourself? This is not a job for a shadetree mechanic you realize?
If you're asking what are you going to have to buy to swap gears and have someone install them, then the gears should come with a kit for the bearings and seals needed. I'd call for estimates in case the bearing and seal kit is extra. Additionally, if your running the 4.0 engine, you'll likely have 3.07 or 3.55 gears stock. Which means a new carrier will be necessary. Buying a Detroit or ARB locker means you won't need a new carrier since they are full carrier lockers.
If you're running a 4 cylinder, then you've got stock 4.10 gears. Changing from 4.10 to 4.56 is not even a half turn on the driveshaft difference and in my opinion, not a very effective cost to performance ratio. In other words, don't bother cause it isn't that big a difference.
Matt Osburn
Greengo
Rigrater Score 1032
osburn is offline   Reply With Quote
