Weight difference - JeepForum.com
post #1 of 9 Old 03-10-2013, 07:41 PM Thread Starter
Bobsgym
Weight difference
Does anybody know the weight difference between a 33x12.50x15 and
33x10.50x15? I'm trying to choose which one I want to put on my tj.
Bobsgym is offline
post #2 of 9 Old 03-10-2013, 07:42 PM
wwch99tj
Depends on the tire... most tire sites list the weight of the tire
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #3 of 9 Old 03-10-2013, 07:48 PM
Trisalsa
Junior Member
Trisalsa's Avatar
Tire rack has tire weights. They list the difference between Goodrich mud terrain t/a tires as 9lbs between the 10.5 and 12.5 tires.
1999 TJ Sport
2010 XK Limited 5.7
Trisalsa is offline
post #4 of 9 Old 03-10-2013, 07:53 PM
JBTJ
I would be more concerned in the gear ratio to turn those 33's than the weight of them. 4.10 for those tires.
JBTJ is offline
post #5 of 9 Old 03-11-2013, 06:57 PM Thread Starter
Bobsgym
I have 4.10's is that not good? From the gear charts I have looked at they all say 4.10's are a good choice.
Bobsgym is offline
post #6 of 9 Old 03-11-2013, 07:07 PM
wwch99tj
What engine?
wwch99tj is offline
post #7 of 9 Old 03-11-2013, 09:28 PM Thread Starter
Bobsgym
2.5
Bobsgym is offline
post #8 of 9 Old 03-12-2013, 05:15 AM
wwch99tj
The 2.5 5 speed has 410/411 from the factory...
You'd need 456 for 31's
Ans 488 for 33's
I have 31's on my 2.5 and its slightly under powered on hills. But other than that its fine. You'd want to regear for 33's
wwch99tj is offline
post #9 of 9 Old 03-15-2013, 11:34 AM
GingerWrangler
I'm running the equivalent of a 33/9.5 tire with a 2.5 with 4:10s
It is not as bad as you think, but i definitely have to use more clutch to start moving. I live in flatland Chicago area, so I don't really have hills to worry about, but i was doing 75 on the highway yesterday no problem in fifth. As long as there is no wind and or hills, you are A-OK!
GingerWrangler is offline
