Want skinny tires. 33" tall and 17" rim - JeepForum.com
post #1 of 16 Old 06-30-2013, 04:13 PM Thread Starter
SDHNTR
Want some aggressive skinny tires that are 33" and will mount on my 17" rims. Running 285 70 17 now but want narrower. What size is similar am I looking for? Thanks.
SDHNTR is offline
post #2 of 16 Old 06-30-2013, 05:03 PM
TimV
BFG makes the km's in a 255/80/R17. Probably about the best you might find.
It's not an addiction. It's a way of life.
TimV is offline
post #3 of 16 Old 07-01-2013, 08:13 AM
mike_dippert
mike_dippert's Avatar
In my search for 33x10.5ish sizes, the 255 is as good as it gets. I've looked through 15, 16, & 17" wheel sizes from most of the companies mentioned on the forum.
mike_dippert is offline
post #4 of 16 Old 07-01-2013, 02:06 PM
floridajpr
2015 JK Wrangler
Interco makes a Super Swamper Narrow S.S. that is only 8" wide but the tire sizes are not for a 17" wheel.
Tire Sizes:
34 x 9.50 x 15LT
9/34 x 16
34 x 9.50 x 16.5LT
floridajpr is offline
post #5 of 16 Old 07-02-2013, 05:12 AM
Charley3
BFG MT KM 255/75R17C (32x10R17) load C. This is a true 32 tall. So 1/2" taller than most brands of 32.
The 75 aspect ratio makes it a good size for on and off road, if put on a 7, 7.5, or 8" wide wheel. A 7.5" wide wheel would be most ideal, but a 7 or 8" wide wheel will work good too.
The 75 aspect ratio tire with a wheel approx 2.5" (2 to 3") narrower than tire's section width is a combination that will give a flat contact patch at reasonable street psi. This has the advantage of increased traction at street pressures. So you won't have to air down for Winter roads or mild to moderate off roading. This is very convenient! This applies to load C tires on a light SUV. Load D or E are to stiff.
I have these perks with my 30x9.5R15 load C on 15x7 wheels. I have 75 aspect ratio and my wheel is 2.5" narrower than my tire section width. I have flat foot print and great traction at street pressure of 28 psi front, 25 psi rear. Just last week I drove through 4" deep mud in 2wd and my Cooper AT3 didn't spin (open diff). I don't need to air down for trails. I might need to air down for uphill on sand or serious rocks, but I won't need to air down much. 20 psi is all I'd air down too fo serious sand or rocks. This is my second set of tires this size. My first set was BFG AT.
255/75R17C is an awesome tire size for DD and Winter roads. BFG makes it in their KM mud tire. I think this is the tire that comes stock on LJ Rubicons.
(Yes, I meant KM, not KM2.)
If the KM is intended for use on wet or Winter roads, get the center treads siped.
I don't know if other tires are made in 255/75R17 load C. If not, they should be.
Edited in Later: At Tire Rack I found about a half dozen AT and half dozen MT in 255/75R17 load C and also passenger P tires. Maybe some load E too. Can't remember. Many good choices. I recommend load C for a Jeep.
There are probably more brands-models of tires in that size that aren't shown at Tire Rack. Tire Rack is not all inclusive. There are many brands they don't carry, including Cooper.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is online now
post #6 of 16 Old 07-02-2013, 05:48 AM
Charley3
Tire Sizes:
34 x 9.50 x 15LT
9/34 x 16
34 x 9.50 x 16.5LT
Those are obsolete bias ply tires, IMO. They'd be lousy on road, IMO.
I assume he wants a modern radial tire. Though maybe I shouldn't assume.
post #7 of 16 Old 07-02-2013, 05:51 AM
Charley3
245 is 9.5" wide
255 is 10" wide (good stuff)
265 is 10.5" wide (good stuff)
Did you look at 245, 255, and 265 tires?
post #8 of 16 Old 07-02-2013, 06:06 AM
Charley3
It's the KM2 that they make in that size. What is load rating? C is best for a Jeep, IMO. Some guys prefer D. But E is way to blanging stiff.
Are any other tires made in that size in load C or D?
235/85R16 (33 x 9.25 R16) is an interesting size, but is only made in load E (to stiff for Jeep), and I prefer 75 aspect ratio for stable sidewalls (better cornering and flat contact patch at a reasonable street pressure).
With combination of load C, 75 aspect ratio, and wheel approx 2.5" narrower than tire section width, I get flat contact patch at nomal street psi. So good traction at street psi and no need to air down for most off road adventures. Airing down only needed for hardcore uphill sand dunes or hardcore rocks. No need to air down for moderate wheeling or Winter roads.
These are reasons why Jeeps and other SUVs usually have stock setup with P or C tires with 75 aspect ratio and wheel 2.5" narrower than tire section width. The engineers usually use this formula for a good DD.
I like to use that setup for a good DD, but do so with a taller than stock tire that is stock width or up to 1.5" wider than stock. Typically I prefer 1/2" to 1" wider tire than stock. It's easily possible to do that with tires taller than stock and keep 75 aspect ratio. Even possible with tires much taller than stock by adjusting wheel diameter so that aspect ratio stays near 75. Also adjust wheel width so it stays 2 to 3" (ideally 2.5") narrower than section width.
I came to these conclusions after running 75 and 85 aspect ratio narrow tires in the past, as well as having tried medium and wide tires too. Having tried an assortment of tire of tire sizes I realized it's not as simple as narrow vs wide. There is more going on: Vehicle weight, tire load rating, tire section width, wheel width, and aspect ratio all combine to affect sidewall stability and cornering, contact patch at street pressure, traction at street pressure, how much air pressure you run on street, ride quality, and gas mileage. Setup properly there is no need to air down for Winter roads or mild to intermediate off roading because tire already has good contact patch and traction at street pressure, and decent ride quality if load C.
post #9 of 16 Old 07-02-2013, 07:25 AM
TimV
That's what I meant. Auto correct changed it on me. I'm sure he would have figured it out when he went tire shopping though.
TimV is offline
post #10 of 16 Old 07-02-2013, 12:30 PM
mike_dippert
245 is 9.5" wide
I know the conversions. I've not seen a 33" DD tire less than 255 in a C or D. E is much more popular in the pickup sized tires.
post #11 of 16 Old 07-03-2013, 01:50 AM
Charley3
Agreed, but no problem because 9.5 to 10 is an ideal width for light SUVs, and 10 to 10.5 is good too. For a Jeep with armor and winch (extra weight) 10.5 is ideal. IMO.
While I prefer narrow to medium width (9.5 to 10.5) tires, a guy an go to narrow for vehicle weight.
IMO getting load C for 1/4 ton SUV is a lot better than D. E is not appropriate.
So I don't think there's a problem.
I'm not really a "narrower is best" guy, even though the "wider is best" guys think I am. I think width appropriate to vehicle weight and intended use(s) is best.
post #12 of 16 Old 07-03-2013, 03:32 PM Thread Starter
SDHNTR
Ok, so say I go with the 255 80 r17. They are e rated, but I can deal with that by softening my shocks- Rancho 9000, right? Now I have an 8.5" wide rim. Any real downside to that wide a rim on that width tire? I don't air down much.
SDHNTR is offline
post #13 of 16 Old 07-06-2013, 01:04 PM
Charley3
I normally recommend 75 aspect ratio, but 80 apsect ratio is good too.
Normally I'd say an 8" wide wheel is widest you'd want to use with a 10" (255 mm) section with tire, but that advice is really for 75 aspect ratio tires.
For an 80 aspect ratio tire, I think an 8.5" wide wheel is fine with a 10" section width tire. In fact, the slightly wider wheel might be better with the 80 aspect ratio.
My only concern is the E load rating. That will be miserably harsh riding on bumps, and the stiffer tire will have less traction because the tread won't conform to the terrain as well as it should. It'd be a lot better if you got a load C tire, or at least a D.
Another consideration is which tire. For any given load rating, BFG AT and Cooper AT3 ride the best of any good off road tires that I know of. Hankook ATM rides almost as good. If you get one of these softer riding tires, it helps ride comfort on and off road, better handling on bumpy highway, and better traction off road, even if it is a load E.
Though those tires (and all tires) would be best in load C for your Jeep.
post #14 of 16 Old 07-06-2013, 01:12 PM
Charley3
P.S. - if you care, load C will get a lot better gas mileage than heavier load ratings.
post #15 of 16 Old 07-13-2013, 12:37 PM Thread Starter
SDHNTR
Ok, so then who makes a good aggressive (more than at) tire in 255 80 17 that is c or d rated? All I could find is the BFG KM2 in E rating.
SDHNTR is offline
