wagoneer wheels on yj - JeepForum.com
post #1 of 9 Old 05-07-2001, 05:05 PM Thread Starter
jmsjeep
I have been told I have wagoneer wheels on my yj. I am looking into a lift and bigger tires. Would I be O.K. using these wheels, I am thinking about 31' -32' tires. Should I look for a set of wrangler wheels and if so what size.
Thanks again
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 9 Old 05-07-2001, 10:49 PM
osburn
osburn's Avatar
You sure they didn't say "wagon wheels"? Wagoneers had the 5 on 5.5 bolt pattern and all YJs have the 5 on 4.5 bolt pattern. Wagoneer wheels wouldn't fit on your stock axles.
Whatever wheels you have, they're sure to work just fine if they're already on the Jeep. Sometimes it pays to get a little more offset when you go to wider tires so you don't lose your turning radius. But otherwise, I'm sure they'll work.
Matt Osburn
Score 1032
osburn is offline
post #3 of 9 Old 05-08-2001, 10:58 AM Thread Starter
jmsjeep
What do you mean by "5 on 5.5 bolt pattern"?
I looked at some pictures online of wagoneer wheels and they look like mine is that good or bad?
By offset do you mean wheel spacers?
Thanks for the info!!!!
jmsjeep is offline
post #4 of 9 Old 05-08-2001, 12:25 PM
rayray
rayray's Avatar
YJ's and TJ's use a 5 on 4.5" pattern. Meaning, 5 lugs, spaced 4.5 inches apart. Wagoneer, CJ's, and so forth use a 5 on 5.5".
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #5 of 9 Old 06-03-2001, 09:39 PM
bluebellyday
I had an older Grand Wagoneer and If I remember it had a 6 lug pattern.
bluebellyday is offline
post #6 of 9 Old 06-05-2001, 02:13 AM
Tonka
2015 JK Wrangler
Hey guys, don't forrget that there was an xj version of the wagoneer and that alot of early xj's came with rims styled like the old fullsize wagoneers. They are 15x7 with a 5 on 4.5 bolt pattern.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #7 of 9 Old 06-06-2001, 02:28 PM Thread Starter
jmsjeep
Tonka -
Your a good man!!!
Thats what my wheels looks like. I started thinking I was going crazy.
I guess I can keep them - I have read that 15x7 are O.K. for 31'-32's
jmsjeep is offline
post #8 of 9 Old 06-06-2001, 04:04 PM
jobob
I have those same wheels on my '90 YJ. They are 15x7 5 on 4.5 pattern. I am currently running 31x10.5 tires on them and they rub the springs during tight turns.
jobob
jobob is offline
post #9 of 9 Old 06-06-2001, 05:07 PM
Tonka
2015 JK Wrangler
I'd run 31,s on a 7 in. rim, but 32' are better left to 8 inch wide rims.
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
Backspacing on stock TJ wheels? Popular aftermarket wheels? STW Tires & Wheels 14 03-12-2011 04:19 PM
Ranger wheels and JK wheels compatable? damunoz32 Tires & Wheels 2 08-31-2009 09:20 PM
Help with possibly Changing 02Jeep Wheels for 06Jeep Wheels.... pong Tires & Wheels 6 04-01-2009 10:27 AM
alcoa wheels or 46.00 steel wheels? jeepcouplenv Tires & Wheels 5 02-27-2007 10:10 PM
