vavle stems!!! - JeepForum.com
post #1 of 11 Old 11-29-2010, 11:48 PM Thread Starter
AviatorNine
vavle stems!!!
do i need spacers to put srt8 rims on my WJ?
im going to get reproductions i guess.. because i cant find any real black srt8 wheels online..
ALSO. my main question. will these vavle stems go on my 04 WJ?
JEEP Cherokee Wheel Tire Valve Stem Caps SRT8 CJ CJ5 - eBay (item 110617316190 end time Nov-30-10 14:12:45 PST)
i'd just have to get 5 sets of the 4 right? so i'd have 5 for each of the 4 wheels?
AviatorNine is offline
post #2 of 11 Old 11-30-2010, 06:03 AM
mdm
Farm Wheeler
Originally Posted by AviatorNine View Post
...i'd just have to get 5 sets of the 4 right? so i'd have 5 for each of the 4 wheels?
Most wheels just have one valve stem. What kind of wheel are you running that would require five valve stem caps?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 11 Old 11-30-2010, 11:38 AM
06_LJCON
Does your jeep have pressure sensors?? Being an 04' I might and if so you do not want to use those caps. If they don't have sensors then yes you can totally use them without any issue.
The 5th one is probably for the spare...
(SOLD) 1991 wrangler 2.5L 5-Speed White, 2" BL, Warn rear bumper, warn winch, warn rock sliders.
(SOLD) 1987 wrangler 2.5L 5-speed BLACK!
S.O.A. with 4" springs and a 2" body lift. Lincon locked front. 33" TSL's NEED bigger tires!!
(WRECKED) 2002 Apex Wrangler 4.0L 5-Speed Silver
2.5" skyjacker single flex, skyjacker shicks, Rock Krawler adjustable lower control arms f/r, 1.25" JKS body lift, 1" JKS motor mount lift, JKS Quicker Disconnects, Warn engine/transmission skid plate, Rock Crusher Front diff cover, Poison spyder rocker knockers, 1.25 wheel spacers, 4.10 gears f/r, Detroit Trutrack rear, aussie automatic locker front
(CURRENT) 2006 Wrangler Rubicon Unlimited LJ 4.0L 6-speep, Silver, 3.5" Rubicon express lift with Rubicon express disconnects. Hella 500 lights, HID Bi-xenon headlights, Rock-It intake, Red top Optima, Factory MOPAR rocker knockers, TNTCustoms Front full tube fenders, 35x12.5R15 BFG KM2, Black steel wheels.
06_LJCON is offline
post #4 of 11 Old 11-30-2010, 11:41 AM
06_LJCON
Wow I just overlooked his original post. NO you do not need more then one set of caps. Each wheel only has one valve stem which uses one valve stem cap.
06_LJCON is offline
post #5 of 11 Old 11-30-2010, 11:45 AM
RussellZJ98
You're wanting to buy 5 sets of 4 to have 4 sets of 5? And questioning spacers? It sounds like you are intending to ask about LUG NUTS and wheel spacers. A wheel and tire will have one valve stem, and require one cap.
RussellZJ98 is offline
post #6 of 11 Old 11-30-2010, 01:38 PM Thread Starter
AviatorNine
sorry, yeah I'm talking about lug nuts. where can I get lug nuts with the pentagon jeep logo.. or other interesting images on the head.
post #7 of 11 Old 11-30-2010, 04:09 PM
RussellZJ98
Can't help you with lug nuts with logos. But you can find some sweet center caps off other jeeps. I wanted these for my ZJ and havent found a cheap set yet. http://www.myaston.com/k/?view=item&...kee+Center+Cap
post #8 of 11 Old 11-30-2010, 09:50 PM Thread Starter
AviatorNine
Originally Posted by RussellZJ98 View Post
Can't help you with lug nuts with logos. But you can find some sweet center caps off other jeeps. I wanted these for my ZJ and havent found a cheap set yet. Jeep Wrangler Cherokee Center Cap
those are cool. and they got me thinking.
will these center caps fit on reproduction srt8 wheels? SRT8 Wheel Center Cap - Jeep Grand Cherokee - Item # 5HT59SZ0AB
post #9 of 11 Old 12-01-2010, 03:37 PM
RussellZJ98
http://www.automotiveaddicts.com/mag...eCaliper01.jpg Sorry, I forgot to mention the center caps I posted earlier would work with after market wheels like the cragar soft 8s. The ones you posted up are the ones that fit the center cap for the jeep wheels.
post #10 of 11 Old 12-01-2010, 09:26 PM Thread Starter
AviatorNine
those are real srt8 wheels though.
see how on these reproduction wheels the center cap is blank?
Special: JEEP, Jeep Grand Cherokee SRT8 Black 20x9 OEM Factory Replacement Wheels & Rims Sets
i wonder if it will pop out so i can put a jeep center cap in.
post #11 of 11 Old 12-01-2010, 10:16 PM
RussellZJ98
There is no center cap in the wheel you posted- nothing to pop out. The circle in the middle is made to fit around the same section of axle, so I'm assuming its the same size, so I'm assuming the center caps in question will fit.
Stop Oil From Leaking from Aluminum Vavle Cover keith460 Cheap Tricks & Fixes 6 11-28-2010 02:20 AM
Valve Stems jeepnatv4life Tires & Wheels 5 12-16-2009 11:26 PM
Do TPMS stems go bad? volcycle Tires & Wheels 1 12-16-2009 10:59 PM
Sheared valve stems UTmike General Jeep & Off-Road Equipment 10 04-08-2009 05:02 AM
Air Valve Stems thudson331 Tires & Wheels 1 01-01-2009 07:18 PM
