to use or not to use.....that is the question - JeepForum.com
post #1 of 8 Old 11-07-2001, 05:56 PM Thread Starter
mytjnamedrex
My friend gave me 4 of these sidewinder radial tires that say 32x11.5 on the side. 2 are usable (were on front). I can get 2 more for under $200. Only thing is that they only measure a little over 30 inches as is (just tire, no wheel). Will it get bigger once its mounted and has air? It looked good on my friends jeep but am wondering on how high it will actually stand...
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
post #2 of 8 Old 11-07-2001, 11:56 PM
evilpsych
evilpsych's Avatar
ok.. roughly $100 apiece for oddly sized tires? you can get new name brand tires for that.. if they were free that'd be another thing..
stick with standard sizes.. if i were you i'd go from 31x10.50 to 33x12's
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 8 Old 11-08-2001, 01:56 AM
igofshn
Locked @ both ends
igofshn's Avatar
All tire makers make there tires a litle different so a 32 by one company might be the same as a 31 by another. Just because it says 32 or whatever doesn't always men that is what it will be.
When mounted it will still be smaller than 32. If your jeep isn't lifted then it will rub. Definately in the front when turning. If you are going to use these tires then I would make sure the other two you get are the same brand.
32X11.50/15 is a standard size.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 8 Old 11-08-2001, 12:07 PM Thread Starter
mytjnamedrex
i was going to do a 2" spacer lift and get some new wheels....The tires will actully only run 85 per tire and are the same kind.
post #5 of 8 Old 11-08-2001, 04:33 PM
I-4
I-4's Avatar
hey rex!what ever became of your brake/bearing problem?you can get 3 procomps for the price of 4 at 4 wheel parts.i bought 5 tires/rims,mounted and balanced for $800(mt's)wouldn't trade my mt's for anything!
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #6 of 8 Old 11-08-2001, 05:43 PM
evilpsych
evilpsych's Avatar
3 for the price of 4? man.. you must be in sales.. :-)
A
post #7 of 8 Old 11-08-2001, 09:30 PM Thread Starter
mytjnamedrex
brake/bearing problem was just that.. the bearings were replaced and i had to get new rotors so i sprung for the performance slotted ones and i now have no more squeeking (even after going mudding) and stopping is alot better. Sorry i didnt update but i didnt think anyone was really that interested.
post #8 of 8 Old 11-09-2001, 05:52 PM
I-4
I-4's Avatar
would you believe i'm a commoner trying to save all the $ i can?i got a bundle of joy on the way!the age old problem of trying to turn $1 into $100. if i ever figure it out i'll share w/ everyone!
95 yj...
I-4 is offline
Newbiee Question?? - grand cherokee thumping question geoff6194 Engines & Drivetrain 0 10-21-2009 11:13 PM
Width of rim question,,,,and **** Cepek rim question. UPSucks Tires & Wheels 3 09-15-2007 09:19 AM
OME vs BDS Question. And Gearing + Tire Question mferrari Tires & Wheels 6 01-15-2006 12:43 AM
Wiring question and meter question Highlander357 Audio, CB & Ham Radios, GPS, & Electrical 4 12-29-2005 01:20 AM
My 2" BB lift question - in depth, and HUGE question WheelinTJ2004 Tires & Wheels 11 02-01-2005 07:17 AM
