Upgrade rims - offset? - JeepForum.com
post #1 of 7 Old 04-13-2013, 01:27 PM Thread Starter
GCSahara
2014 JK Wrangler
I'm in a 2011 Wrangler Sahara Unlimited that has yet to be modified. I'm looking to drop down to 17" rims from 18" originals to accommodate a larger tire. What is the MINIMUM offset to not be labeled "aggressive"? Tirerack is telling me >25mm and another is telling me >15mm is ok. I am not planning on changing out the fender nor lifting the suspension. Only rims and corresponding larger tires. Thanks for the help!
GCSahara is offline
post #2 of 7 Old 04-13-2013, 02:50 PM
222Doc
222Doc's Avatar
Depends on tire width. if its any tire in the 12.5 wide. Back space should be 4.5"MIN. offset is in the negitive numbers though, should be more like
-10/15. two ways to measure the same thing. Some site give conflicting info as well.
222Doc is online now
post #3 of 7 Old 04-13-2013, 03:53 PM Thread Starter
GCSahara
2014 JK Wrangler
Thanks. Unfortunately I'm not following the explanation, the main part being that I was advised offset can never be negative.
GCSahara is offline
post #4 of 7 Old 04-13-2013, 04:48 PM
MyKeyB
Not sure how much this will help but...
Offset is measured from the rims center line. Positive offset moves the rim more to the inside of the vehicle and negitive offset moves it more to the outside of the vehicle.
Backspacing is measured from the backside of the rim to the point where it contacts the hub. Higher backspacing measurements move the rim more under the vehicle and lower measurements move the rim more to the outside.
Like 222Doc said it's two ways to measure the same thing. I know what both are and how they work but to me backspacing is easier to understand and figure out. Also offset is more commonly used on FWD and backspacing is more commonly used on RWD/4WD.
Rust never sleeps...
MyKeyB is offline
post #5 of 7 Old 04-13-2013, 04:59 PM Thread Starter
GCSahara
2014 JK Wrangler
Thanks - that diagram is a great way to visualize this whole topic. So based on 222Doc any rim I choose should should have 4.5" backspace. The below one I was told I can't have based on the offset being negative (no reference to backspace)
http://www.quadratec.com/products/92605_6123.htm
GCSahara is offline
post #6 of 7 Old 04-13-2013, 05:48 PM
MyKeyB
Well an 8 lug rim will not work for you, that's for sure. It really depends how big of a tire you want to run. I'm not familiar with JKs at all. I can tell you from the quick research I did this rim:
http://www.quadratec.com/products/92605_6100_07.htm
(Same rim you linked but in correct bolt pattern) will stick out about 1.75 inches further than the stock 18" rims. Will it fit? It'll bolt on. Depending on tires it may or may not rub. I'm sure someone more familiar with JK's will chime in and help. Aggressive? That's up to you. I like a tire that sticks out a bit. Just the rim sticking out an extra 1.75" and then a tire hanging an inch or two even further out? Sounds a little aggressive to me.
For reference from what I found. The JK is a 5x5 bolt pattern. Your optional Sahara rims should be an 18x7.5 with 6.25" backspacing. If you want to keep it close to stock try and match up these measurments. Maybe look for a 17x8 with 5.5-6" backspacing. Remember the lower the backspacing the further it will stick out. Like I said I know nothing about JK's and this is real general information so take all this with a grain of salt.
MyKeyB is offline
post #7 of 7 Old 04-14-2013, 08:10 AM Thread Starter
GCSahara
2014 JK Wrangler
Great advice. Thanks for the help...
GCSahara is offline
offset , rim size , rims , sahara
