Undecided between STTs or Duratrac's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Undecided between STTs or Duratrac's
50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Opt**new!!** pandemic-usa led pod lights!! Siiiiick!!!07-15 JEEP JK Inner axle tube Sleeves
Unread 03-26-2013, 05:05 PM   #1
Gary2
I am undecided between Cooper STT and GY Duratrac at this point and would like to hear some of your experienced thoughts on each. I am interested in knowing how much weight if out of the ordinary either has required to balance , if any odd highway handling quirks or pretty much anything that seems to stand out about either , good or bad . 33-12.50x15 is the size . I am replacing a set of BFG ATs that seem to have a mind of their own on the road and required way way to much weight to balance compared to any tire I have owned in 40 years. Thats including many sets of BFG ATs but none like these .
Gary2 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2013, 10:46 PM   #2
tyvanwie
Duratracs. I have the 33x12.5 and love em
Sent from my iForum using JeepPhone
[SIZE="4"][B][COLOR="Red"][URL="http://www.jeepforum.com/forum/f22/tys-tj-1475530/#post14926343"]MY BUILD THREAD[/URL][/COLOR][/B][/SIZE]
[SIZE="4"][B][URL="http://www.jeepforum.com/forum/f374/tyvanwies-log-transformation-1489190/"]MY FITNESS LOG/TRANSFORMATION[/URL][/B][/SIZE]
[SIZE="4"][B][URL="http://www.jeepforum.com/forum/f127/jk-tj-parts-1525039/"]JK AND TJ PARTS FOR SALE[/URL][/B][/SIZE]
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is online now   Reply With Quote Quick reply to this message
Unread 03-26-2013, 11:39 PM   #3
OCS12
My last set of tires were STT's, currently running Duratracs. Both sets 33X12.5. Duratracs have been better in every way. With 20K miles on my Duratracs (I commute 90 miles a day, so the miles add up fast) I'm very impressed with how they're holding up. They're also far better in snow if that's an issue for you.
I had no complaints about the Coopers at all, the Duratracs just impressed me more. When I wear out this set, I'll be buying 5 more of the exact same tire.
OCS12 is offline   Reply With Quote Quick reply to this message
Unread 03-29-2013, 05:49 PM   #4
Gary2
No one cares for the Cooper STT ?
Unread 03-29-2013, 06:36 PM   #5
fourbtgait
1930 MK Patriot
Looking at buying myself, I like the STT more than Duratrec but more for sidewall protection in the sharp rock in my area.
They just weigh 7# or more each so not sure with my axle ratio.
fourbtgait is offline   Reply With Quote Quick reply to this message
Unread 03-29-2013, 07:40 PM   #6
EDM
I like the STT's very much but have no experience with the DuraTrac to make a comparison.
EDM is offline   Reply With Quote Quick reply to this message
Unread 03-30-2013, 05:38 AM   #7
Gary2
I like the tread pattern on the STTs but I am leary of the weight. I sold the OE MOABs that came on it so I could get a lighter C rated instesd of a D or E's . I have 12.50 33 BFG ATs now and if I dont run at least 31 lbs in them they are all over the road if it is not a perfectly flat road. I want something with a more aggressive tread with out being all over the road. My last TJ had 35" Maxxis Bighorns and actually they were fine I just thought I would try something else this time
Unread 03-30-2013, 09:28 AM   #8
fourbtgait
1930 MK Patriot
I started looking at the Hankook Dynapro MT, decent traction, lighter weight. I would have to get them siped but I would add more to the STT also. Probably less of a hit to mpg also.
Unread 03-30-2013, 09:34 AM   #9
jrallen
jrallen's Avatar
FWIW, 10 lbs. at the axle is equivalent to 100 lbs. of cargo. I'd save weight there if it were up to me...
jrallen is offline   Reply With Quote Quick reply to this message
Unread 03-30-2013, 09:57 AM   #10
fourbtgait
1930 MK Patriot
Yes, ive read/seen that before, thats why I havent jumped the gun. The CJ has good performance now on/off road with 3.54 ratio and a tire weighing 40# +/-, dont want to loose it by jumping to much.
Unread 03-30-2013, 11:26 AM   #11
Gary2
I know I have posted that rule of thumb on many forums myself which is my my concern about the weight naturally . The Nitto and Toyos are some of the heaviest tires out their but yet they also seem to require the least amount of weight of themajority of the tires so I guess their is a positive side to a couple of the heavy weights.
Unread 03-30-2013, 11:54 AM   #12
KKiowaTJ
Go with the STT's. The duratrac's cant hold a candle to them unless on road. The STT will last longer, More biting lugs and edges, tek3 sidewall vs paper thin, The same life span in miles etc But you get traction everywhere with the STT's. They take very little to balance and dont chunk so rebalancing is not an issue. To each his own, Good luck
YJ, TJ, XJ, ZJ..... Too many Jeeps!
KKiowaTJ is offline   Reply With Quote Quick reply to this message
Unread 03-30-2013, 11:56 AM   #13
fourbtgait
1930 MK Patriot
True. Ive had the toyos on diesel trucks, good heavy tires.
For a jeep it comes down to 2 ply or 3 ply sidewall for the weight diference.
Unread 03-30-2013, 10:18 PM   #14
1995_XJ
1995 XJ Cherokee
I love my STT's, I'm on my second set
Never had duratracs though.
1995 Cherokee Sport
1995_XJ is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 06:53 AM   #15
pmcjeep
I like my stt's also!
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline   Reply With Quote Quick reply to this message
