Undecided between STTs or Duratrac's - Page 4 - JeepForum.com
post #46 of 80 Old 04-06-2013, 05:08 PM Thread Starter
Gary2
Originally Posted by billiebob View Post
I am replacing a set of BFG ATs that seem to have a mind of their own on the road and required way way to much weight to balance
Anyone else have this problem? I have had a set of BFG ATs on something forever and never had a problem. On my Wrangler I get 100K Miles if I run them till they are almost bald. And balancing has never been an issue.
Out of probably over a dozen sets of BFG's on my DDs this is the first that acted like this . I have since decided to sell the 5 ,15x8 Ultra 50/51 wheels also and will be using 285/75/16s on Moabs . Gaining a little more back spacing tends to give the Jeep a little more leverage in the steering dept and little less wandering also.
Gary2 is offline
post #47 of 80 Old 04-06-2013, 05:08 PM
Redrocklocal
I had a set of 35's on a JK Rubi and got less than 30k out of them. They did great in the loose earth and just OK in the snow. I would give them a C+ in the rocks and ledges of Moab. I just got back from a spring break week in Moab and took my Grand this time. It is a bit more mild. 4in. under her, with just one locker and a disconnected front. I run 245 75's 16's in the Dura trac. I have just over 34k on the set with more than 50% tread remaining. I aired down to about 20lbs and literally walked stuff that I had struggled a bit on in the Rubi last year. The WJ grand is my DD. and I could not be more pleased with these tires. I will buy them again. Both tires are more aggressive than others so I did get some road noise from both sets. When I first bought the STT's I got one that was out of round. I kept going back to Discount Tire with my complaint and they would re balance. After I did my homework to make sure no steering and suspension parts were loose or worn they did eventually replace the tire. After that they were much better. My Dura Trac's although 3 inches shorter are a much better all around tire. I consider them magic in the snow, and get a B+ or A- on all other things. You have a lot of input here, hopefully it helps your decision.
Redrocklocal is offline
post #48 of 80 Old 04-06-2013, 05:34 PM
Windrider
I have STTs on my F150 for 25k miles and Duratracs on my Cherokee for 10k miles.
Different vehicles, but similar style tires.
Duratracs balance easier and stay in balance better.
I would give a nod to the Duratracs on the road for comfort and noise.
On road wet weather performance goes to the duratrac.
I would give the nod to the STTs off road for Durability in rocks.
In clay type mud they perform similarly. Neither clean as easily as a true mud tire and both a way better than the BFG AT and General Grabbers that I have used.
Neither have dug in too bad on sandy (not pure sand) type soil.
Howdy. Six years lurking. I think this is my first post.
Windrider is offline
post #49 of 80 Old 04-06-2013, 08:08 PM
RSPRAGGINS
Tires for the jeep
See this site for the tires i prefer behind a Z06-LS6 CJ7 Jeep.
http://blog.liveoffroad.com/jeep-cj-...m=6&gallery=25
got over 40k miles on last set with almost half tread left.
SUPER SWAMPERs FROM INTERCO SSR-33 X 12.5 X 15. Were almost impossible to find for a long time, but now Interco is making their own of this style. Prediator 4 wheel shop, best/oldest in Colorado Springs folks all run this tire and they some serious wheeling and they drive their rigs to the area, not trailered.
If you want milder, the old BF Good TA/Radial is still the best, but expensive.
Son got 80k miles on his last set on a Grand Cherkee.
P.s. Stay away from C & R Radiators, had 2 start leaking in 4k miles and they won't honor replacing or even answering emails, even said to go to Ron Davis Radiators, which is my next one.
RSPRAGGINS is offline
post #50 of 80 Old 04-06-2013, 11:34 PM
Poe_jc
Currently running the 31x 10.5 15 STT's on a stock TJ and couldn't be happier. No hard 4wd action at this point but everything I've been in I've had no issues with traction (rain, gravel, sand & etc). After comparing different brands for several months I chose the Coopers due to their pattern, side walls, and great dry rot guarantee (which is a concern in Vegas).
Poe_jc is offline
post #51 of 80 Old 04-07-2013, 06:24 AM
lukes_ranger
I really like the duratracs ran them on my truck and was traveling 60 miles a day. Put 5k miles on them, and still looked brand new. Then I sold the truck. But doesn't the duratracs wear fast in hot weather? How many miles are u guys getting out of them in hot weather?
lukes_ranger is offline
post #52 of 80 Old 04-07-2013, 11:18 AM
JCTJeep11
Cooper Discoverer ATP
I'm running the Cooper Discoverer ATP (LT285/70R17)(33's) on Black Alloy Rims - Awesome tires for on and off the pavement - very little to no road noise - Great in the snow and rain - no issues at all in the sand (air-down to 15 PSI) - have had no issues on the mountain trails. Have not tried on rock climbing. Purchased at Discount Tire, I get great service and prices from the folks at Discount Tires. They will always have my business.
JCTJeep11 is offline
post #53 of 80 Old 04-07-2013, 03:43 PM
TrailRated2011
2011 JK Wrangler
285/75R16 GY Wrangler DuraTrac E
@Gary2
I have used GY Wrangler DuraTrac E on my 2011 JK 2dr for 2+ years.
Dislikes: None
Likes: Traction (rock crawling, mud, snow, gravel); tread wear; value for money; great agressive look (lots of people/passers-by take notice and tell me they like the tires' look); quiet and comfortable highway ride; great snow traction; studdable (for ice); built-in rim protector to help protect wheels from accidental damage on and off-road; and plenty of grip and side bite!
N.B. Meets Provincial laws in Quebec, Canada for mandatory winter tires. Mountain/Snowflake symbol branded on the Duratrac's sidewall identifies tires that meet the required performance in snow testing and provincial requirements.
Side Note: I just completed a road trip a couple of weeks ago (Canada to Miami Fl. USA I-81 to I-95) Ottawa, Ontario to Miami-Dade South, Florida return trip-----quiet and comfortable highway ride. Amazing!
TrailRated2011
Canada - Nat'l Capital Region
Know your angles before approaching obstacles and
follow the general rule of off-roading, "Go as slow as you can, as fast as you must."
I'm on the Web: geres.ca
TrailRated2011 is offline
post #54 of 80 Old 04-07-2013, 06:32 PM
Nebraska4X4
hey didn't read all of the thread other than the first part i have the duratrac 33x12.50 on my 99 xj and couldn't be happier in my opinion i would say the next best thing would be swampers
[]IIIIIIII[]
Nebraska4X4 is offline
post #55 of 80 Old 04-07-2013, 07:46 PM
rvrdvr
I have a set of the 33x12.5R15 Duratracs and love them. They are much quieter than the BFG MT the po had on it. Better in the rain too!
rvrdvr is offline
post #56 of 80 Old 04-08-2013, 10:38 AM
1998zj
They are much quieter and better on the street because they are an AT tire, not a mud tire.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #57 of 80 Old 04-08-2013, 10:45 AM
lukes_ranger
^this^
post #58 of 80 Old 04-10-2013, 09:48 AM
bbacus
STT or Duratracs
I do have one thing to say and that is most of the MT tires you will find are pretty good. This is more of a personal/subjective decision. I think STTs are a great tire for the price. They drive well on the highway and are durable off road. However, MT's are notoriously bad on ice and wet pavement. Keep that in mind. If you are an extreme off roader, you should look at extreme tires...keeping in mind most of them are expensive...for good reason.
After a lot of research, not personal experience, I also like Toyo Open Country MTs. They are massive and durable. Bottom line here, is that Duratracs are an AT tire. Not even close to STT which is an MT tire. If the Duratrac is a decent tire it should wear better than the STT. Compare like tires guys. AT's are better highway tires and have better wet road/icey road handling characteristics. Duratracs would not hold up where I off road. AT's are simply a weaker tire than any MT. If you think you are getting a better tire, there are tradeoffs between offroad capability and highway capability. AT's, simply won't do the job where an MT is required. If you want good specialized tires like swampers, or sand tires, that's great, but they are terrible on hard surfaces. Determine what is most important to you first. If you want a tire that lasts longer and drives down the highway better, choose an AT. I want off road durability and strength, so the minimum tire that I can buy is an MT.
bbacus is offline
post #59 of 80 Old 04-10-2013, 03:41 PM
KKiowaTJ
Its obvious you have only bought one set of tires that didnt go on a car. Next best thing to swampers?
MOPAR!
KKiowaTJ is offline
post #60 of 80 Old 04-10-2013, 04:46 PM
MountainMan864
or the cooper st max is an even better option. I'd go with those over duratracs Any day.
MountainMan864 is offline
