Trying to understand offset as it relates to backspacing? Looking at these wheels. - JeepForum.com
post #1 of 5 Old 03-30-2011, 11:46 PM Thread Starter
Rubi Unlimited
So..... Backspacing is from the inner mounting surface of the wheel to the inside rim of the wheel.
Wheel offset as I understand it is how far off the actual center line of the wheel the mounting surface is.
Would I need wheel spacers to run this wheel if I was going with 255/80r17 on a 3.5 inch OME lift (2005 Unlimited Rubicon)? It is the wheel offset that has me baffled. As I understand it 4 inch or 3.5 inch backspacing does not require spacers these wheels are 4.75 which I would presume would need the spacers. But does that have anything to do with or account for an individual wheels offset?
I have found some wheels I like (Raceline Renegade 5 wheels)
The manufacturer site
http://www.racelinewheels.com/p-648-17-renegade-5-black-machined.aspx
Here they are being pushed by Discount tire on another forum.
http://forums.off-road.com/discount-tire-direct/235460-raceline-renegade-5-forum-member-special.html
Cleverly disguised as responsible adult.
Rubi Unlimited is offline
post #2 of 5 Old 03-31-2011, 02:56 AM
RogueSpear2023
Those wheels have 0mm offset, and 4" of BS so to run them you will need spacers to use them.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #3 of 5 Old 03-31-2011, 07:14 AM Thread Starter
Rubi Unlimited
Actually they have 4.75" which is even worse than 4" and I presume spacers to be necessary just wanted to make sure.
But as to the other question how does offset correlate to or effect backspacing if at all.
post #4 of 5 Old 03-31-2011, 07:34 AM
mdm
Farm Wheeler
http://www.customtacos.com/tech/index.php?article=40
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 5 Old 03-31-2011, 12:12 PM Thread Starter
Rubi Unlimited
So Offset has no relavence to backspacing and you do not add or subtract it from the backspace number to find an "actual backspacing" number. OK thanks.
what is 0 offset set on backspacing? zaathur151 Tires & Wheels 18 10-28-2011 10:41 PM
Do I understand backspacing yet??? Luck881 Tires & Wheels 5 06-05-2009 10:24 AM
Offset & backspacing... veritas Tires & Wheels 8 09-01-2003 11:43 PM
offset and backspacing sheepdog Tires & Wheels 3 08-13-2003 08:58 PM
Backspacing, Offset Briznett Tires & Wheels 2 06-15-2003 10:58 PM
