Quantcast Trying to make tire choice - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Trying to make tire choice
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 11-07-2009, 07:46 PM   #1
youngdog17
So i really like the yokohama geolander mts but i dont know if they have the size for my stock rim. I really like the stock rims. The tires on it now are 225/70/r16 and my jeep has 2in coil spacers i think the biggest i can fit are 31s? I dont know if yokohama geolander mt makes a 31 that will fit my stock rim?
If anyone knows or can help that would be great.
I have done some research but couldt find the answers to my questions.
youngdog17 is offline   Reply With Quote
Old 11-08-2009, 07:26 AM   #2
Junky burp
I like the look of directional tread....that's a nice looking tire. This is all I can get. The 265 75 16 (I know this translates to 10.5x 31.75x 16, but often times, the physical tire is a smaller size.)
YOKOHAMA GEOLANDAR M/T-S
Junky burp is offline   Reply With Quote
Old 11-08-2009, 08:15 AM   #3
Apollo21
hmm that may be cutting it close. you may have to trim.
Patrick- MIDN 2/C USMS (USN)
Skipper of [I]SIRINA[/I] 1969 31' Bertram
2002 Red Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, sweet headlights, rear addco, spring retainers, KOR SS, liftgate light, Alpine/Polk speakers, and power inverter with USB.
Build thread [url]http://www.jeepforum.com/forum/f22/apollo21-build-thread-902929/[/url]
[QUOTE=Jerry Bransford;11691320]Worrying too much about mpg with a Jeep is similar to worrying about your sister's virginity. An ok thing to be concerned about but...[/QUOTE]
Apollo21 is offline   Reply With Quote
Old 11-08-2009, 11:30 AM   #4
youngdog17
I dont mind triming alittle i just dont wanna hack it up. So whats the siz of my stock rims? 10.50x8?
Old 11-08-2009, 05:46 PM   #5
Junky burp
The 235 85 16 looks to be the same height, but (9.25?) wide. Dunno if that helps. Your rims will be 16 (diameter) x something wide.
Old 11-08-2009, 08:49 PM   #6
youngdog17
Im trying to figure out how wide my stockers are? I know there 16s but how wide are the 16s? and whats the MAX width i can put on my stocker?
also when tire sizes are listed 265/70/16 what is the 265 metric???? cm? mm? what im trying to find out is 265 a 31 tire 30 tire or what how do you convert it to inchs????
Old 11-08-2009, 09:09 PM   #7
CB3
265 (millimeters) means it's approx 10.5" wide from sidewall bulge to sidewall bulge. i.e. - it's a 10.5" wide tire. Approximately.
Not sure how tall a 265/70/R16 is, but I'd guess it's about 31" tall. Why would you get that tire?
Get a 265/75R16 because that's a 32 X 10.5 R16 and it fits stock TJ and LJ with stock Rubicon Moab rims, and will probably fit your WJ too.
However, I'm not an expert on WJ tire fit. So someone else will have to help you with that, but I'd suggest you consider 265/75R16 tires because that's a great size, and a few brands of that are available in load C (my preference), and many brands in load D.
I'd suggest you get load C for best ride quality (durable enough for me). If you want a more durable tire, get a load D (but it will ride rougher). Avoid load E because they ride so rough you'd regret it.
CB3 is offline   Reply With Quote
Old 11-08-2009, 09:33 PM   #8
youngdog17
the only problem with a 32 is i dont think it will fit. i have a 2001 wj grand cherokee with a 2inch coil spacer lift so i think the biggest i can go is 31s. so im trying to see what size tire i can get thats a 31 but everone list there sizes in metric (265/70/16) i really want the yokohama geolander mt but they only have 265/75/16 all im trying to figure out is will that tire fit my stock rim and clear the body and bumpers????????
Old 11-09-2009, 06:17 AM   #9
+Crusader+
Does that tire design require having 2 spares, one for left side of vehicle, and one for the right?
"The only physical problem Obamacare won't be able to fix, is bustin' your @$$." – Dennis Miller
+Crusader+ is offline   Reply With Quote
Old 11-09-2009, 06:09 PM   #10
Junky burp
I've read that putting directional treads on backwards is about as dangerous as removing the "DO NOT REMOVE THIS TAG" tag from your mattress. I also read some wheelers will run the fronts in reverse purposely in case they need the extra benefit to back out of a situation.
The tire design is basically a farm tractor tire with more technology, made to churn soil from under it to get down to more solid ground below.
From a physical perspective, the idea of a donut shape displacing dirt remains the same in both instances, running it one direction has a little more advantage.
Old 11-09-2009, 06:26 PM   #11
Junky burp
Take 265. (this is millimeters)
divide that by 25.4 (that's how many millimeters are in an inch)
that equals 10.43 inches (round that up to 10.5)
....That tire is 10.5' wide at it's widest point.
take 70 (that is the percentage of tire width to height ratio.
so.. 10.5(width) and multiply by 0.70(percentage value)
that equals 7.35 inches (we're not done yet)
that means the fatness is 10.5 and the height is 7.35, but that's only half the tire (a section- like you cut the tire from the hole to the outside)
so that would be 7.35 on the top and 7.35 on the bottom.
that's 14.7"
All you need to do is add the wheel (rim) diameter and VOILA! Overall tire height.
I can't help you with your stock wheels, but alot of people put 10.5" wide tires on a 7" wheel.
Old 11-09-2009, 07:14 PM   #12
youngdog17
Thank you junky burp thats what i wanted.
Old 11-10-2009, 05:26 AM   #13
Junky burp
Just remember, not all tires are really true to their advertised measurements. Most times they are a little smaller, but (not that I've seen this) some are bigger and this may be true of the SIMEX off-road tires.
I've read a thread here that those tires run 1" taller than the advertised measurement, but have not confirmed it personally.
Pricing puts those out of my practical interest.
Good luck.
Old 11-12-2009, 02:43 PM   #14
JCDriller
I just put 265/75R16 Nitto Terra grapplers on my WJ with only a 2"BB, new shocks will go on in about 2 weeks when I get time. I did have to trim, due to rubbing when the wheels were turned in reverse, but it was a 1 hour job, unnoticeable unless you look for it and works like a charm.
This was taken before I trimmed
JCDriller is offline   Reply With Quote
Old 11-12-2009, 08:42 PM   #15
youngdog17
Thats good to know. but what all did you have to trim? and about how much? any more pics of wjs with 265-75-16s would be awesome or tires close to that size.
Glock Forum
