#1 | |
Trying to avoid death wobble
Hi, I am new to this forum and a first time Jeep owner. I bought a 05 Rubicon Unlimited and want to lift it in the future. I have read those who have lifted their Jeeps sometimes experience death wobble. I think this is due to going over 3" with a short arm suspension lift. If I lift my Jeep 4 or 4 1/2 " and use a long arm suspension lift, will I prevent death wobble?
#2 |
I have a 4" Full Traction lift and have ZERO problems. The key is proper tire balance, and a good alignment. Some folks will say a steering stabilizer only masks a problem, but I am of the few that believe thats what its supposed to do. I am still on short arms and am quite pleased with the performance of my lift. I have no quams about putting anyone behind the wheel of my heep, including my wife and my 17 year old niece. Death wobble really is a troublesome issue, but for most it comes when they piece together a lift and do NOT add all the essential components. A good quality lift, with balanced tires and aligned properly will drive as well as a stock jeep. Good luck, theres lots of decisions ahead, ask all the questions you can think of and while your reading the answers be saving your $$ for the best.
Jason
DD-- 2005 Dodge Ram 2500 Cummins TD Quad Cab 4x4 6 speed Toys: 1998 Sport Auto trans, 3.73 gears, D30/lockright D44/Detroit, 33" Mud tires, FT LCA's JKS Adj. Trac bar FT 4" coils, RE GEN II Disco's--1 1/4 JKS BL, 1" MML XD9000i up front, HD bumpers with extraction points.-Done. 1973 cz 250 MX Not much suspension, but 36 BHP at 6k rpms! 2006 Rhino SE, 27" Mud lites and a cupholder. http://www.caos4x4.com/cmbs/index.php |
#3 |
Farm Wheeler
As you lift the vehicle/run larger tires the vehicle is more likely to experience DW but DW can happen to a vehicle with stock tires and suspension.
The type of lift really doesn't play into the mix. The causes of DW are usually an out-of-balance tire combined with loose suspension parts (the track bar is the most common culprit). Unbalanced tires and loose/worn suspension parts can happen regardless of the lift installed. |
#4 | |
pirate squirrel
- Chuck - Nth Degree 4.5" short arm the "Dude" abides Last edited by numchuck; 04-12-2007 at 07:43 AM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
