TrXus best all around MT? - Page 5 - JeepForum.com
post #61 of 192 Old 01-11-2014, 04:37 AM Thread Starter
Ed209
Originally Posted by tjkj2002 View Post
I have 13k on a set of 35" MT/R K's and they are wearing very evenly.Then again I actually check the tire pressures weekly,rotate and balance them every 1500 miles,and keep the alignment good(checked every 1500 miles).
No tire will wear evenly unless you actually do a little work.
If that's what it takes to make MTRKs wear evenly, I wouldn't put them on if they were a gift.
Ed209 is offline
post #62 of 192 Old 01-11-2014, 05:22 AM
hustler905
It's not, I rotated mine every second oil change and had no problems.
hustler905 is offline
post #63 of 192 Old 01-11-2014, 05:26 AM
tjkj2002
2002 KJ Liberty
I'm a little more OCD about maintenance then most since I get to see daily what neglect does to vehicles.
tjkj2002 is offline
post #64 of 192 Old 01-11-2014, 07:45 AM
biffgnar
biffgnar's Avatar
1500 seems a little over the top, but I do think MTRs like to be rotated more frequently than most tires. I rotate mine every 3k. On my third set. Best multi-use tire for our application out there.
biffgnar is offline
post #65 of 192 Old 01-11-2014, 08:22 AM Thread Starter
Ed209
That's more reasonable and what I do too. My tire shop gives free rotations every 7000 miles with a new set of tires.
Ed209 is offline
post #66 of 192 Old 01-11-2014, 08:31 AM Thread Starter
Ed209
3000 is over the top in my book. It's got to be that wanked up tread pattern. Have you actually run the TrXus to know it's not as good or better than MTRKs?
Ed209 is offline
post #67 of 192 Old 01-11-2014, 10:25 AM
biffgnar
biffgnar's Avatar
No I haven't. If I wanted a true MT with a softer compound they are one I would consider, although probably would not be my choice. But for how my jeep is used I want a multi-use tire that will last longer. I'd rather rotate tires every 3k than buy new ones twice as often.
biffgnar is offline
post #68 of 192 Old 01-11-2014, 03:30 PM
KKiowaTJ
The mt/r is 'maximum traction/reinforced' with Kevlar. Not a 'mud tire'.
No way in hell the trxus will last longer than kevlars, I have over 35k on mine now as I have been DD it again as my truck is down. We have had ice the last week and I have had nothing but maximum traction on ice.
Mine are currently sitting at 13/32's give or take what the rear Detroit chews.
But why not go with the trxus? You narrowed it down, It will suit you best, You only drive X amount of miles in it a year, how can you go wrong with a tire you piced and have done the homework?
Unless you think there is a better or don't want to run them for any reason, The Kevlar is the closest tire you will find. They just have a 'look' you don't like, That's cool, I didn't either until I tried them.
Whats the reason for not pulling the trigger on the trxus?
MOPAR!
KKiowaTJ is offline
post #69 of 192 Old 01-11-2014, 06:17 PM
tjkj2002
2002 KJ Liberty
The more aggressive the tire the more often it should be rotated,alot sooner if you have a auto locker.Also if you fail to fix scrub radius and SAI angles if you lift your rig you need to rotate more often.But hey I get paid to rotate/balance my tires and to check the alignment so why not do it often?Besides my Jeep does not get driven that much,1500 miles used to take 6 months but now will take a year after picking up a '03 Town Car and the MT/R K's are wheeling tires only as I run Destination MT's for daily driven tires.
I have run both the Trxus MT and the MT/R K's(and old style MT/R's) and the MT/R K's(and old style MT/R's) wins hands down.
tjkj2002 is offline
post #70 of 192 Old 01-11-2014, 08:00 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by KKiowaTJ View Post
The mt/r is 'maximum traction/reinforced' with Kevlar. Not a 'mud tire'...
It doesn't say mud tire on the sidewall, but they work pretty good in the mud.
At least as good or better than other tires that say mud on the side.
Wheelin98TJ is offline
post #71 of 192 Old 01-11-2014, 08:35 PM
KKiowaTJ
I think they do well for being a traction tire. Clean out with little to no wheel spin. Anything better would have to be a mud grappler or Irok/bogger, Dedicated off road tires.
You can only expect so much out of a tire. If you want performance here, It will lack there. Best happy medium is the Kevlar or MTZ IMO. Have had great experience with both traction, Durability and going the distance mileage wise.
I also rotate at 3k or before. If at 3k, that's because I was lazy. I want the best wear and grip, I have had these same kevlars doing the same routine going on four years in april.
MOPAR!
KKiowaTJ is offline
post #72 of 192 Old 01-11-2014, 09:13 PM Thread Starter
Ed209
I'm in no hurry. I'm also looking at the Pro Comp Xtreme MT 2, which has a harder compound than the TrX and a 40K mile warranty.
Of course the TrXus, a true soft compound MT, won't last as long as the MTRK street compound tire. And how could MTRK be the closest to what I want, when you just said it's not even an MT. I said from the git-go that I'm going to an MT, not a hybrid, especially one which only has serious looking tread on the outer half of the tire.
Ed209 is offline
post #73 of 192 Old 01-11-2014, 10:50 PM
KKiowaTJ
Im not trying to sell ya on something you don't want, If you think it will lack in mud you are wrong. That and it being a hybrid? Far from it, Just a first of its kind asymmetrical tread that does above and beyond any tire in its class, For not being a 'mud' tire.
Just curious why you questioned them after its pretty much what you want. But at 30k tops, And you can find something comparable with a 40k minimum, Well that's a no brainer.
Good luck either way, If you are not in a hurry it helps compare with no time 'need' looming over.
MOPAR!
KKiowaTJ is offline
post #74 of 192 Old 01-11-2014, 10:58 PM
FAW-CAN-ADIAN
Wheelin around the west coast of BC the mtrs will outlast the trxus hands down..I have also seen three trxus sidewall failures.never seen an mtr sidewall fail..damn pokey roots.Either way,both good tires..I would still like to kick mr Goodyear in the balls for retiring the old style mtr.
FAW-CAN-ADIAN is offline
post #75 of 192 Old 01-12-2014, 07:39 AM Thread Starter
Ed209
Let me get this straight, it's not MT, not a hybrid, and it's above and beyond any tire in it's class - what class? GY say's it's a street tire!
Ed209 is offline
