TrXus best all around MT? - Page 13 - JeepForum.com
post #181 of 192 Old 04-11-2014, 06:12 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Originally Posted by Ed209 View Post
Two things, TrXus MT has a channel running straight down the center of the tread I don't like, which can cause the car to follow irregularities on the road. And, they have a roundish cross section as opposed to square like the MTZ, which I also don't like, cause you have to run low pressures with 7" rims to get full tread contact, and I'm not a rock crawler.
Aggressive tires have always been known to track and pull those irregularities in the road and should be expected. They are designed to grab and that's what they're doing. It can be particularly more noticeable on a narrow track, short wheelbase vehicle. some tires do this much more so than others. Iroks for instance, would occasionally cause unintended lane changes for me. Not good and downright scary from time to time.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #182 of 192 Old 04-11-2014, 02:59 PM Thread Starter
Ed209
Originally Posted by Charley3 View Post
Use 15 x 8 wheels for 31 x 10.5 and you'll get a flatter contact patch with any brand tire. That would be especially helpful with Trxus MT. IMO
Right, except there are no 15x8s with 5" BS I like and I already have 15x7s with 4.5" BS, which avoid rubbing, stay tucked under a stock Rubicon flare, and exactly preserve the track of the stock combo of 245/75-16 on 16x8 Moabs. The solution is a 31x9.5-15 or a narrow 31x10.5-15 like the KM2.
Ed209 is offline
post #183 of 192 Old 04-11-2014, 09:41 PM
Ken Cooke
Originally Posted by tophog View Post
My local discount tire has no problem getting Truxus MT's ... last time their supplier(S) were out so they ordered directly from Interco. Just saying. A lot depends on the store manager and how much they will go out of their way to get what a customer wants vs selling something they have sitting on the back shelf.
This gives me an idea...I'll call around - I'll drive south to San Diego for a new set of TrXus MTs instead of running my BFGs for 1 more year.
My last set of TrXus MTs...
Ken Cooke is offline
post #184 of 192 Old 04-12-2014, 12:18 AM
Charley3
There's 15 x 8 with 4.5 BS, which is close, or perhaps you could get a wheel custom made?
If you were going to use 31 x 10.5 R15, would those clear mounted on a stock 15 x 8 with 5.5 BS? I'm not sure. Perhaps others can answer this.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #185 of 192 Old 04-14-2014, 12:09 PM Thread Starter
Ed209
4.5 will stick out and 5.5 will (almost certainly) require steering stop shims. I refuse to compromise, when 15x7 with 4.5 BS and 15x8 with 5 BS are perfect.
Ed209 is offline
post #186 of 192 Old 04-14-2014, 08:00 PM
Charley3
So what are you going to do?
Charley3 is offline
post #187 of 192 Old 04-15-2014, 03:30 PM Thread Starter
Ed209
Leaning toward KM2s on 15x8s, since they're round, stay balanced, are about the narrowest 31x10.5 M/T out there, and I'm convinced I can spin em clean with 4.10s & two lockers.
Ed209 is offline
post #188 of 192 Old 04-16-2014, 11:36 AM
KKiowaTJ
So you jumped from the strong side of sidewall tires to the worst paper thin ones? Many other tires to choose from, The MTZ or the STT would be your best bet for a tire that will clean and have traction with a strong sidewall with a perfect balance every time.
MOPAR!
KKiowaTJ is offline
post #189 of 192 Old 04-16-2014, 11:53 AM Thread Starter
Ed209
They are 3 ply, and are certainly not as thin as some others. If you search on this forum, there is more than one report of sidewall failure on even the MTRK. MTZs have good rep for sidewall strength, but are among the widest of the 31x10.5s, and would rub on my 15x8s with 5.25 BS. STTs get marginal reviews in clearing mud - they're more of an AT than MT - not much, if any, better than my Grabber AT2s. And they are also very wide. KM2s have a great rep around here, and local prices are reasonable.
Ed209 is offline
post #190 of 192 Old 04-16-2014, 05:03 PM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
I think that's a good choice for you as the KM2s have a good rep here as well.
post #191 of 192 Old 04-17-2014, 11:47 AM Thread Starter
Ed209
Encouraging to hear they have a good rep down your way too! Another plus is the year round widespread availability.
Ed209 is offline
post #192 of 192 Old 04-24-2014, 02:35 PM
RubiLongSox
I prefer my STTs over my old KM2s in almost every respect.
2006 LJ Rubicon
1948 Willys CJ2A
RubiLongSox is offline
