TrXus best all around MT? - Page 12 - JeepForum.com
post #166 of 192 Old 04-06-2014, 11:32 PM
Charley3
Originally Posted by Ed209 View Post
Would TrXus do any better than these 33" KM2s, unlocked front & rear?
Yes. A friend of mine with Trxus MT ran circles around guys with KM2 in challenging mud.
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #167 of 192 Old 04-07-2014, 09:27 AM
CJ7nvrstk
http://www.youtube.com/watch?v=RS3OErJE7xI
Doubtful. Given the way he was driving it he wouldn't have done any better with boggers. Wheel spin is needed to clean out the lugs and there was none there.
For all the KM2 haters out there, its clearly evident that the Truxus is such a better tire as evidenced by how many people run them on the trails.
I can count the number of wheelers I see wheeling them on less than 1 hand. in fact, I haven't seen a set of those on the trail in like 5 years. They are just so superior that everyone is running them.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #168 of 192 Old 04-07-2014, 09:50 AM
tophog
You need to come to the PNW where there are actually hills/mountains over 200'
tophog is offline
post #169 of 192 Old 04-07-2014, 10:55 AM
CJ7nvrstk
Didn't see anyone running them in the Rockies either, and those are certainly higher than 200'.
post #170 of 192 Old 04-07-2014, 11:24 AM
tophog
They must had a rocky mountain "high"
tophog is offline
post #171 of 192 Old 04-07-2014, 02:26 PM Thread Starter
Ed209
I think you're onto why a few don't like KM2s - not enough wheel spin to clear out along with no front locker to spin both fronts. I've seen lots of pics on here that show KM2s cleaning out nicely and going through axle deep mud.
Ed209 is offline
post #172 of 192 Old 04-07-2014, 07:08 PM
Charley3
One advantage of smaller tire sizes is you can spin them faster with little fear of breakage.
Do that with a large tire size and breakage is more likely of a tire suddenly finds traction.
On the other hand, larger tires are less likely to need to be spun fast to get er done.
Charley3 is offline
post #173 of 192 Old 04-08-2014, 09:52 AM
CJ7nvrstk
Yup, if you don't know how to drive or simply don't have enough power to spin the tires it doesn't matter what type of MT it is, you'll just clog up the lugs and that makes forward progress tough, regardless of tire choice. You might as well be running an AT if you aren't going to use them to their fullest potential.
post #174 of 192 Old 04-08-2014, 10:02 AM
CJ7nvrstk
Be careful with saying you can spin smaller tires with little fear of breakage as that is simply not true. If that were the case, I wouldn't have broken a R&P while running 31s and then grenaded the carrier the next year. Bad advice read on the Internet can cause some bad feelings.
As for your last statement as well, you still need to spin with the larger tires to clear mud.
post #175 of 192 Old 04-08-2014, 12:21 PM
KKiowaTJ
I watched the km2 fail time after time. When I ran them I had more than plenty of enough 'wheel speed' to clean them out. Plus their sidewall is a step above their a/t so lacks their too.
Its BFG best attempt at the worst copy ever made. They are nowhere close to the krawlers they copied them after. They actually got the job done and had deep tread voids, Unlike the km2 turf tamer tread. In my area, Nobody runs the **** km2's and highly doubtful that will change.
Maybe some soccer moms do at the grocery store, But not on the trails or back roads where I spend the vast majority of my time.
MOPAR!
KKiowaTJ is offline
post #176 of 192 Old 04-08-2014, 03:40 PM
Charley3
Huh. Well I used to spin 235 ATs like crazy in mud and got through with no breakage. Did that for years with no problems, but I'm sure anything can break.
When I had larger MT (33s are large to me) I never had to spin them because they got it done without needing that.
But of course deeper gooier mud could still make spinning a larger tire necessary.
There are no guarantees, but when spinning tires fast and getting after it hard, which is more likely to break something? Small or large tires? Each person can decide and draw their own conclusions.
Charley3 is offline
post #177 of 192 Old 04-08-2014, 05:39 PM
Charley3
I think Ed (the OP) was asking about 31" Trxus MT.
In that size I think they'd be reasonably civilized on road and reasonably easy to balance.
For mud, Trxus MT have 3 stage outer lugs, which clean well according to every Trxus MT user I've known.
Life, wear, and durability were already discussed.
Is there anything about Trxus MT that hasn't already been covered in this thread?
Charley3 is offline
post #178 of 192 Old 04-09-2014, 02:17 PM Thread Starter
Ed209
Two things, TrXus MT has a channel running straight down the center of the tread I don't like, which can cause the car to follow irregularities on the road. And, they have a roundish cross section as opposed to square like the MTZ, which I also don't like, cause you have to run low pressures with 7" rims to get full tread contact, and I'm not a rock crawler.
Ed209 is offline
post #179 of 192 Old 04-09-2014, 09:06 PM
Charley3
They have a roundish cross section as opposed to square like the MTZ, which I also don't like, cause you have to run low pressures with 7" rims to get full tread contact, and I'm not a rock crawler.
Use 15 x 8 wheels for 31 x 10.5 and you'll get a flatter contact patch with any brand tire. That would be especially helpful with Trxus MT. IMO
Charley3 is offline
post #180 of 192 Old 04-09-2014, 09:10 PM
Charley3
I'm not disagreeing or agreeing about center channel following irregularities in the road. I don't know.
How do you know?
I'm not disagreeing. I'm just curious.
That center groove probably provides some lateral traction off road and on Winter roads.
Charley3 is offline
