Treadwright (retread) poll
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
| View Poll Results: If you have used retread tires you: | |||
| Used Treadwrights and they worked great (would recommend). |
80 | 86.02% |
| Used Treadwrights and they didn't work well (not recommend). |
3 | 3.23% |
| Used other brand retread and they worked great . |
8 | 8.60% |
| Used other brand retread and they didn't work well. |
4 | 4.30% |
| Multiple Choice Poll. Voters: 93. You may not vote on this poll | |||
#46 | |||
Ive put 10K miles on my 31" Gaurd Dog's, highway, in town, etc and it didnt DRASTICALLY change my MPG... and I LOVE them.
-Dave Quote:
#47 | |
2001 XJ Sport 4.5" RC LA Custom snorkel Detours/winch Flux Capacitor Heat Machine |
#48 |
Whats the "PSI Chalk Test"? can someone explain?
#49 | |
Pull onto a quiet street. draw a straight line across your tread with a piece of chalk. drive it down the road a few hundred feet. get out and see if it evenly wore the chalk line or if you got more wear on the center of the tire, etc... if you have more wear on the center of the tire, then you have too much PSI... let some out and do it again until you have a nice, even wear.
-Dave Quote:
#50 | |
Thanks guys, I'm sold
NightCrew #125 Quote:
#51 |
shhh....bump....
#52 |
After doing a lot of research on Tread Wrights, I'm going to order a set for my Jeep. I think I'm going with the 265/75/16 Guard Dogs.
#53 |
Let everyone know how it turns out.... I think when it comes time I will get the treadwrights also.
#54 | |
Well mine showed up three weeks early, guess the backorder deal on the guard dogs got cleared up? I lose 2-3 mpgs highway, turnin is squishy, and they track/wander an uncomfortbale bit. but they are on bfg a/t 3-ply sidewalls. so thus far, cant say good or bad about treadwrights tire, but i will say i dont like these casings. will comment later on the tread quality. i will say this for now though, holy WOW are the tread lugs deep.
#55 | |
what air pressure are you running?
#56 |
yeah it sounds like you aren't running them high enough
Patrick- MIDN 2/C USMS (USN) Skipper of [I]SIRINA[/I] 1969 31' Bertram 2002 Red Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, sweet headlights, rear addco, spring retainers, KOR SS, liftgate light, Alpine/Polk speakers, and power inverter with USB. Build thread [url]http://www.jeepforum.com/forum/f22/apollo21-build-thread-902929/[/url] [QUOTE=Jerry Bransford;11691320]Worrying too much about mpg with a Jeep is similar to worrying about your sister's virginity. An ok thing to be concerned about but...[/QUOTE] |
#57 | |
all four 31x10.5-15 treawright gurad dogs on bfgoodrich a/t ko 3 plys set at 36 psi, rated up to fifty. I must admit, haven't chalk tested, its been too wet. what should they be set to?
#58 |
Depends on the sidewall specs. What does it state on the sidewall?
#59 |
ran mine at 39 when i first got them because that's what the 16 year old tech set them to, currently i run 32psi
#60 | |
@ muddeprived: not a recommended pressure found, only the max of 50.
@ apollo: If you run them at 32, mine couldn't be low like suggested could they? Would running them lower help do you think?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
