Tread Wright Tires...Any Good? - Page 6 - JeepForum.com
post #76 of 215 Old 09-06-2010, 11:07 AM
bonehead99
bonehead99's Avatar
Originally Posted by theducksguts View Post
I don't recall anyone saying they didn't like the crawlers.
Don't recall my post saying that people didn't like them. Maybe I worded it wrong.
My question is why did you pick the Gaurd Dog pattern over the other 2 patterns. Most people in this thread have talked about the GD pattern and I want to see if their is a reason they like it better.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #77 of 215 Old 09-06-2010, 11:37 AM
Mike_Motorbike
I think the Guard Dog looks like a factory tire and the Crawler looks like a retread tire...
And the Guard Dog is really more of an aggressive AT and the Crawler looks like a half worn out mud tire ......
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #78 of 215 Old 09-06-2010, 12:14 PM
theducksguts
I went with the Guard Dog because it fits more with they type of driving and wheeling my wife does. She will drive the rig every day but wheel it on mild/moderate trails. With the type of soil we have here in WI the BFG AT patterns tend to muck up pretty good leaving you with slicks.
The MTR pattern is a nice go between between an AT and a serious mud tire. Basically it fits better for what we will be using the rig for.
Check out my
theducksguts is offline
post #79 of 215 Old 09-06-2010, 01:13 PM
fitbmxseries1
1987 YJ Wrangler
wish they still did the 33s on 15"s discontinued.... boo!
fitbmxseries1 is offline
post #80 of 215 Old 09-06-2010, 01:43 PM
PeriwinkleZJ
I would pick them up if they had a larger 15" selection. I'm not sure if it's worth spending the extra $200 on new rims when I could use it from a brand new tire anyway. Now if I came across some CL rims, or maybe a junkyard set of stock 16"s then I could see myself picking up the metric 285/75 which is equivelant of a 33x11.50 which is nice because I like skinnier tires anyway.
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:
PeriwinkleZJ is offline
post #81 of 215 Old 09-06-2010, 03:12 PM
theducksguts
you shouldn't limit yourself to 15 inch wheels. There is nothing wrong with running 16's or 17's with bigger tires. you have to draw the line somewhere though
Check out my
post #82 of 215 Old 09-09-2010, 01:44 PM
theducksguts
I received my 31 by 10.5/15 Guard Dog MT/R's today. All 5 of them on a 3 ply BFG AT KO casing. My first impression is that they were very clean. All of the marks made in the retreading process were buffed out and they look very good. You can tell that they are retreaded tires but they are very solid.
There are no gaps in the tread and it basically looks perfect. As you can tell from the above photo you can see where they joined the tread to the casing. I spoke with TW about their process of creating the new tread. I was surprised to hear that it isn't something that is just glued on. They use a computer automated process to add new rubber to the casing after preparing it for the mating. After the new rubber is cured it is given the design.
I was assured by TW that they balance test and examine the quality of each unit that goes out.
Here are some more pictures.
One of the things I noticed about the casings is that they are well broken in. I have had tires shipped to me in the past. They were all brand new tires. My TSL sidewalls were very stiff and took a while to break in. I guess I don't have to wait for these sidewalls to loosen up.
They will likely be mounted and balanced on 15/8 aluminum wheels within the next week. More pictures and more evaluation will be on the way.
Check out my
post #83 of 215 Old 09-09-2010, 02:25 PM
fitbmxseries1
1987 YJ Wrangler
I can never find a good 16 inch rim with the right spacing that i want for cheap. if i find some used 16s on craigslist ill grab them quick. Whats the equal size in metric sizing? (equil to 33s) not to concerned on width though
post #84 of 215 Old 09-09-2010, 05:37 PM
Bishop Creek
Nice! Just curious, did you measure the height to see if they are a true 31 inches?
ďThis isnít the Old West, because the New West has never arrived. Itís just the West, like Wyatt Earp died yesterday.Ē
─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996.
Bishop Creek is offline
post #85 of 215 Old 09-09-2010, 05:39 PM
Muddeprived
Muddeprived's Avatar
Interesting. Do they make the 15's and 16's differently? My 16's have a divider going along the middle of the tread and it throws off the design a little bit. Your tires don't have this. I have 16's though.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #86 of 215 Old 09-09-2010, 07:26 PM
theducksguts
I don't have a line going through the center so I don't know what that is about. I couldn't find my tape measure this afternoon to see if they are 31"
Check out my
post #87 of 215 Old 09-10-2010, 08:01 AM
theducksguts
Here is a link that helped me understand what I was buying.
Understanding Retreading
It is a PDF file and requires Adobe Reader or a comparable open source reader.
To answer a question asked above on the actual tire height. I measured this morning and they are 30.5ish inches tall. I'm sure this has something to do more with the casings used than the tread added to the tire.
Other casings I imagine might be taller or shorter depending on the brand.
Check out my
post #88 of 215 Old 09-10-2010, 08:29 AM
Muddeprived
That should come out to 31" when aired up. Mine were 265/75/16's and came to 32" tall unmounted and about 32.5" aired up.
post #89 of 215 Old 09-10-2010, 01:14 PM
fitbmxseries1
1987 YJ Wrangler
is tread wright the only place that does offroad retreads?
post #90 of 215 Old 09-10-2010, 01:59 PM
theducksguts
I bet with some searching you could find something. I haven't found any as well known as TreadWright. maybe Stone Tire, but haven't heard anything from them in a long time.
Check out my
Tread Wright MTG - ULTRA GRIP noise_maker Tires & Wheels 5 06-16-2009 06:23 PM
Tread wright 265/75/16s anybody run them? snakester14 Tires & Wheels 3 11-20-2008 12:23 AM
MT's for daily driving. which has good performance and high tread life MEinSoCal Tires & Wheels 13 02-07-2008 01:41 PM
Anyone running re-tread tires offroad? Bot Tires & Wheels 2 11-11-2006 12:56 PM
tires: tread width and C.S.: what are they? TJeepPir Tires & Wheels 2 01-21-2004 12:44 AM
