Tread Wright Tires...Any Good? - Page 14 - JeepForum.com
post #196 of 215 Old 04-20-2014, 07:42 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
I'm curious, what kind of "detailed instruction" did TW give the installer? What has to be done differently when mounting these then mounting an off the shelf tire?
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #197 of 215 Old 04-20-2014, 09:32 AM
strvger01
1966 CJ5
i know one thing is they balance their tires before they ship them. when the installer balances them mounted on the wheel, they are actually trying to compensate for the wheel rather than the tires. i ran into that situation on my last set of TW tires. the installer had a ton of wheel weights stuck on my wheels and they rode like crap. pulled off all the weights and now they are fine. no issues at all.
that was just my experience. i'm definitely a TW fan and will continue to buy their tires. i will also just have the installer mount them without balancing them.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #198 of 215 Old 04-21-2014, 07:35 PM
Motophile
The tires are so simple to balance that it goes against the logic of every tire mounting guru I met in the last week.
Next time I will keep it more simple than the simple instructions provided.
Step one: Spin mounted tire using the Static (single number) setting and put weights in the Static position.
Step two: Put half the weight on the inside of the rim and half the weight on the outside of the rim in the same location (if static reading calls for 8 oz, then 4 oz on both inner and outer sides)
DONE!
Tire guru's brain will explode but if he spins it again it will come out perfect, even if there appears to be lumps or wiggles. Drives perfect up to 80mph, no vibrations.
I recommend going to some crappy little tire place where you can watch and make sure they follow the SIMPLE procedure. Walmart is free lifetime balance and rotation so try if you are up to it.
Motophile is offline
post #199 of 215 Old 04-22-2014, 01:56 AM
MTBlue
I just ordered my own set of Guard Dog's. Went with the 265/70R16 because, well, budget boost (for now). Anyway, I went with load range D because I wasn't sure what all the (P) range consisted of... I got an email early this morning from customer service telling me that they didn't have any Kedge Grip in stock (which is what I ordered), but they do have a set of regular's ready to ship this week. From all I've read here and on other sources, the Kedge Grip is worth every bit of the $10 extra/tire. So I opted to wait on the KG option, seeing as I won't be home for another 2 months due to a deployment and can afford to wait it out. Still waiting to hear back with a confirmation of my decision, but I am impressed by TW's customer service so far. Keeping my fingers crossed for a GOOD set the first time around, since I will only have 2 weeks at home to play with them
Dirt Deprived
MTBlue is offline
post #200 of 215 Old 04-23-2014, 01:16 PM
strvger01
1966 CJ5
i had the Kedge Grip on my first set of their Axiom AT tires. they did quite well here in northern Minnesota. almost as good as studded tires really. btw, chains and studded tires are illegal here in Mn. they were worth the extra money for me then. the set i got last summer, i didn't get the Kedge Grip so i'll have to see how they do next winter. they are on my cj5a which spent this past winter in the middle of an engine swap.
post #201 of 215 Old 06-06-2014, 05:55 AM
Muddeprived
Muddeprived's Avatar
Ok I think I have a problem here. Check out the pix:
These are 235/75/R15 crawlers from Treadwright. They are two years old with a bout 8-9k miles on them. Three of the four are doing this. I have guard dogs that are almost 7 years old with 20-some thousand miles on them and still like 80% tread remaining but they do not look like these at all. They are still mint! I emailed treadwright twice but got no reply and it's been a few weeks.
Does anyone's tires look similar? I'm not really worried but the concern is there.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #202 of 215 Old 06-06-2014, 06:02 AM
MTBlue
You got old casings. They're probably older than 6 years, so you'll get cracking and separating. That's the only downside to TreadWrights, really.
Dirt Deprived
MTBlue is offline
post #203 of 215 Old 06-06-2014, 06:23 AM
Muddeprived
But it's not the old casing that's separating/cracking. It's above the edge of the retreaded portion of the sidewall so it's the new cap that's doing this.
Unless you meant that the old tire causes the new cap to crack?
post #204 of 215 Old 06-06-2014, 07:01 AM
MTBlue
It's a possibility. Not very likely, but possible.
Dirt Deprived
MTBlue is offline
post #205 of 215 Old 06-06-2014, 07:56 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
That doesn't look good.
post #206 of 215 Old 06-06-2014, 05:30 PM
strvger01
1966 CJ5
i'm assuming you sent those pics with your email. i'd give them a call for sure. iirc, they have a 2 year warranty so depending on how close you are to that, they should take care of you.
post #207 of 215 Old 06-06-2014, 06:54 PM
Muddeprived
Got a reply through my gmail account. (Note: Comcast does not seem to be able to send emails to Treadwright for some reason but gmail works. )
"Chris,
I was looking at the pictures that you have sent over , and it seems to be some cracking where the tread meets the casings . Yes , you might want to replace the tires. I was looking at your order and your well pasted the two year warranty .
I do apologize , i wish i could help you out.
Sincerely ,
Erik "
Not exactly helpful to me but I can't expect them to be since I passed the warranty period. I gotta think this over and decide if I want to deal with Treadwright again.
post #208 of 215 Old 06-07-2014, 06:17 AM
mschi772
1997 XJ Cherokee
Eh, sometimes **** just happens. I'd wager their support/response might be slow yet due to them moving and upgrading all their stuff to B2B. That's not an excuse but more of just a possible reason. There's nothing I hate more than a customer service department that doesn't respond quickly even if it's just to say, "Hey, we got your email. We're really busy with things right now, but we will get to you as soon as possible." I mean, how hard is it really to check an email inbox once or more per day and let people know they're not being ignored?
I'm a fan of Treadwright and a pretty understanding guy, but this one instance of someone saying that multiple emails went unanswered for weeks is enough to have already started turning me off to Treadwright (this is assuming your gmail email was sent weeks ago, too). That's just inexcusable. I bet I'm not the only one who'll ever read this and feel that way--potentially a lot of lost customers or missed opportunities because someone couldn't be bothered to stay on top of their email account. Sad. Hopefully someone at Treadwright is perceptive enough to recognize how they screwed-up here and learn a lesson.
Speaking of bead-to-bead, I wonder if that new method of theirs would provide significantly greater protection from something like this occurring...
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #209 of 215 Old 06-07-2014, 07:02 AM
Muddeprived
My comcast emails went unanswered but my gmail message was sent the day before yesterday and they replied the next day so I'm assuming comcast servers and treadwright servers don't mesh well. I've had issues with comcast not sending emails or me not receiving certain emails. But yeah I hate when emails do go unanswered, forcing you to call, which is difficult for me because i'm hearing impaired and cannot hear on a phone.
Considering my issue, where the cracks and gaps are occurring above the tread cap edge, I don't know if B2B would be any different. If it was occurring on the edge of the cap, where it was starting to unpeel off the casing then yeah I would think B2B would work better. I sent a reply their message asking about the B2B tires and if they are prone to something like this as well.
I was thinking of getting 31x10.5R15 B2B Guard dogs, since my other regular guard dogs have lasted all these years and still got another 4-6 years left in the tread, but I don't know if I want to take the chance again. I do love the GD tires cuz they look awesome, perform great in all conditions, and last freakin forever!
I'll see what Treadwright says about the B2B tires.
post #210 of 215 Old 06-07-2014, 08:19 AM
WXman
I've used the Guard Dog and the Warden and I had great success with both of them in every condition and usage imaginable which I have talked about in many threads. But.... here is my beef with the new B2B design they are using: First of all it adds even more weight to an already heavy tire. The remolding process adds 8-12 lbs of weight to the tires in the 30-32" sizes. If you get a B2B tire, then you're also adding weight to the sidewalls as well. So what that means is that a set of these Treadwrights can add as much as 60 lbs. of unsprung weight to your Jeep. This destroys fuel economy, braking, accel, and can wear out joints faster and if you have any signs of death wobble it will make that worse as well. Weight is bad. And B2B makes an already heavy tire worse. Second, it covers up all of the original manufacturer info. You have no idea when the tire was originally made, what the original weight capacity was, what the original brand was, or anything else. The B2B mold covers up all of that info and you are getting a "mystery" tire. I do not like this.
I am a big fan of Treadwright and I like the idea of keeping tires out of the landfill for a few more years of life, but I don't like their new molds. And also, once you add shipping costs you will find that tires they sell are approaching the prices of brand new tires now. For example, a set of Treadwright Wardens in 265 size runs over $500 shipped. A set of brand new ATs can be purchased from discounttiredirect.com for the same money. Granted, different tread patterns but then again the old BFG tread pattern sucks anyway.
This is why I haven't bought Treadwrights in the last two years.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
Tread Wright MTG - ULTRA GRIP noise_maker Tires & Wheels 5 06-16-2009 06:23 PM
Tread wright 265/75/16s anybody run them? snakester14 Tires & Wheels 3 11-20-2008 12:23 AM
MT's for daily driving. which has good performance and high tread life MEinSoCal Tires & Wheels 13 02-07-2008 01:41 PM
Anyone running re-tread tires offroad? Bot Tires & Wheels 2 11-11-2006 12:56 PM
tires: tread width and C.S.: what are they? TJeepPir Tires & Wheels 2 01-21-2004 12:44 AM
