TPMS Question / Please Help - JeepForum.com
post #1 of 1 Old 07-22-2012, 03:35 PM Thread Starter
GeckoFun
So I just got my new wheels/tires installed last week 275/65/18 DuraTracs on GF-X Wheels. They were balanced and mounted with TPMS at Discount Tire Direct and I have since dropped the PSI to 30. I drove like that for a few days without issue.
Then I tried to install the LED Recon front driving lights without the load resistor and when I did the car registered that the those two lights were out and they blinked fast. This also made the TMPS indicator light come on that the tires are low. This literally happened exactly when I installed these lights. I checked all the tires and they are still 30 PSI.
I have gone back to stock lights and they are working fine with no error code on the lights, and they blink normal. But the TPMS is still warning there is a low tire.
What gives? Could the lights have tripped something? Could a TPMS fail after a few days? Is 30 psi too low for this system on an E rated tire? Can a wheel/tire shop test to see if each TPMS is working without taking off the tire?
Thanks in advance!
GeckoFun is offline
tpms sensers? jeepwonder Tires & Wheels 2 06-10-2012 11:06 AM
Tpms question PAJAY Tires & Wheels 3 01-24-2012 06:43 PM
TPMS scanner straty1987 Audio, CB & Ham Radios, GPS, & Electrical 0 05-31-2010 10:39 PM
Do TPMS stems go bad? volcycle Tires & Wheels 1 12-16-2009 11:59 PM
TPMS W/ New Wheels? JeepKJ10 Tires & Wheels 0 07-02-2008 10:51 PM
