tj wears right front only - JeepForum.com
post #1 of 6 Old 07-24-2012, 08:52 AM Thread Starter
C54
Hi I have been racking my brain as to why my tj would wear the out side of the right front tire and none of the others. I have a three inch lift. I was trying to get by for a few months without buying trackbars but I might not have a choice. I looked at the left front and it is wearing normal. I would think if it was an alignment issue it would wear both tires. I also checked the knuckles they also seem fine. I am stumped.
C54 is offline
post #2 of 6 Old 07-24-2012, 09:14 AM
biffgnar
biffgnar's Avatar
Trackbar unlikely to help what you are describing. Something is wrong on that side of the front setup. Look at your jeep from the front. Does it look like you have excessively positive camber on the side that is wearing? When you say you checked the knuckles what does that mean? Did you check ball joints? Unit bearing? Control arm bushings? Is the axle tube on that side straight?
Romney in 2020!
biffgnar is offline
post #3 of 6 Old 07-24-2012, 09:26 AM Thread Starter
C54
I checked the ball joints. Nothing appears to be bent. I rotated my tires about a 1500 miles ago, when I did that I didn't not any camber issues then. But beings the outside of the tire is worn its kinda hard to tell right now.
C54 is offline
post #4 of 6 Old 07-24-2012, 09:48 AM
hustler905
Take a picture for us.
hustler905 is offline
post #5 of 6 Old 07-30-2012, 07:01 PM Thread Starter
C54
Ok I got pics but don't have photobucket or anything. Could I just like to Facebook?
C54 is offline
post #6 of 6 Old 07-30-2012, 07:15 PM
ltrail
1984 XJ Cherokee
You can link FB to photobucket lol. Just sign up for one of many image sites and most are free.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
np231 front output yoke. is ANY front/back play normal? Blk2kTj Engines & Drivetrain 1 01-25-2008 08:17 PM
Any Mud tire that wears well? Or get an AT? Srhmn8r Tires & Wheels 7 06-07-2006 08:14 AM
Replace only front speakers or front and rear? Stricken Audio, CB & Ham Radios, GPS, & Electrical 2 07-03-2004 12:39 PM
