Quantcast TJ 15x8 4.0" backspace with 31x12.5" tire? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > TJ 15x8 4.0" backspace with 31x12.5" tire?
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 03-05-2009, 01:20 PM   #1
Hocky
I have a set of 31x12.5" TSL Bogger tires and I am looking to order a second set of wheels for them. My TJ has about 3.5" of lift on it. Can I get away with a 15x8" 4.0" backspace wheel with this tire combo? Cragar soft 8's are super cheap and available in this size.
Yes, I searched, and I failed. Any input would be appreciated.
Hocky
1994 Acura Integra - JDM B18, Carbon Fiber Wing
1998 Wrangler - Aftermarket sound bar, Sony Xplode head unit, diamond plate rocker covers
Hocky is offline   Reply With Quote
Old 03-05-2009, 01:33 PM   #2
jeep95xj
1995 XJ Cherokee
id go 15x10 with a 3.75 back spacing. Boggers are over sized and wider than they actually state they are. They are also a super heavy tire. before you use them make sure your bearings and joints are all in great shape. Also dont even bother trying to balance them. You cant
jeep95xj is offline   Reply With Quote
Old 03-05-2009, 01:40 PM   #3
Hocky
No argument, but I want to be a cheap ***. Can what I posted in the OP work? haha
Hocky
Old 03-05-2009, 02:00 PM   #4
Hocky
Looks like I can get a set around the same price with a 3.75" backspace... would that be preferable?
edit: After digging through some more searches, it looks like this is the route that I want to go.
Hocky
Old 03-05-2009, 05:40 PM   #5
CB3
Well, I won't swear to it, but I'm pretty sure that you could safely go with 15 X 8 with 4" BS for that 31 X 12.5 tire.
I'm using a 15 X 8 with 4.5 BS with a 33 X 10.5 tire and it fits great. My tire is 2" taller, but 2" narrower. So really that should be the same clearance issues and fit for a 33 X 10.5 as for a 31 X 12.5 with regard to rubbing swaybar or LCA during turning. I have full lock to lock turning without rubbing (though I do have round JKS LCAs) and I did NOT have to adjust steer stops to get it. Turns on a dime.
I think that a 15 X 8 wheel with 4.5 BS with your 31 X 12.5 tire would give you the same great fit that I get with my 15 X 8 wheel with 4.5 BS with my 33 X 10.5 tire. So a 15 X 8 with 4 BS should give you extra clearance, IMO. Also, 4" BS would give less bumpsteer and puddle pull than 3.75" would. i.e. - I think that 4" would actually be preferable over 3.75", IMO. 4.5" BS would be even better yet, if you have round LCAs, a bit of lift, and your front swaybar links adjusted properly for the lift.
P.S. - I have 3" lift, round LCAs, and my swaybar adjusted with adjustable links, all of which increases my tire clearance enough to allow me to do great with 15 X 8 with 4.5 BS and 33 X 10.5 R15 tires with full turning radius. If you had those advantages going for you, I think you could use 4.5 BS and love it. If you have some of those going for you, I think you could use 4" BS. If you have none of those, then you might need 3.75" BS.
CB3 is offline   Reply With Quote
Glock Forum
