Tires & Wheels (Wheel width for 12.50 wide tires) - JeepForum.com
post #1 of 17 Old 12-04-2009, 07:26 PM Thread Starter
cowboy1107
I have a 2000 TJ with a rough country 2.5" suspension lift and 1.25" BL. I want to put **** Cepick Mud Country tires 33x12.5x15 on Soft 8 wheels. I know I need 4'' back spacing max but is it acceptable to put those tires on 8'' rims?
cowboy1107 is offline
post #2 of 17 Old 12-04-2009, 07:29 PM
ActionJackson
15x8 is recommended for a 33x12.50 tire.
I hope you're talking about 8" wide wheel, not an 8" wheel.
RED JEEP CLUB MEMBER #519
ActionJackson is offline
post #3 of 17 Old 12-04-2009, 07:33 PM Thread Starter
cowboy1107
Thanks for the reply. Yes, 8'' wide LOL
post #4 of 17 Old 12-04-2009, 09:07 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Yes, you will be fine!!!!!!!!!!!!
GOLENJEEPTJ is offline
post #5 of 17 Old 12-04-2009, 09:17 PM
SkylinesSuck
What about that size tire on a 15x7" rim?
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #6 of 17 Old 12-06-2009, 12:37 AM
+Crusader+
I've ran that too, it stiffens up the sidewall some (slightly roughter ride), but holds a bead slightly better too. The 8's are a better fit overall.
"The only physical problem Obamacare won't be able to fix, is bustin' your @$$." – Dennis Miller
+Crusader+ is offline
post #7 of 17 Old 12-06-2009, 04:12 PM
Albertaaviator
Hi All
Will 31x10.5x15 tires fit a stock Jeep Grand Cherokee...no lift kit!
Thanks
Dan
Albertaaviator is offline
post #8 of 17 Old 12-06-2009, 06:38 PM
Shdy4x4
I have a 2000 Jeep Wrangler TJ Sport with a 1 3/4" coil spacer lift. I currently have **** Cepek DC-1 wheels on it. Can I run Mickey Thompson MTZ 33x12.5x15 ???? I DO NOT use this vehicle for off roading yet. I will not use it for off roading until I get a suspension lift larger than what is on it now. I only put about 800 miles on the Jeep a year.
Thank You,
Ryan
Shdy4x4 is offline
post #9 of 17 Old 12-07-2009, 02:37 AM
+Crusader+
^^^ These two guys are competing for a Thread Jack.
JF, it never disappoints!
post #10 of 17 Old 12-07-2009, 03:06 AM
RogueSpear2023
Thank You,
Ryan
Originally Posted by Albertaaviator View Post
Hi All
Thanks
Dan
Go start new threads grand Cherokee guy go ask in you tech section for info, this is more for wheels and tires questions on what will fit. Same goes for you 2000 TJ Sport.
To the OP yes 8" wide wheels are fine for a 12.5" wide tire.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #11 of 17 Old 12-07-2009, 12:11 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Hi All
Thanks
Dan
Which Grand? ZJ, WJ or WK?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #12 of 17 Old 12-07-2009, 12:34 PM
Albertaaviator
Wow, not sure. Its a 1996 Jeep Grand Cherokee Laredo 5.2 litr all stock
Here's a pic
post #13 of 17 Old 12-07-2009, 12:41 PM
Albertaaviator
This was my first time in this forum! My first post! But thank you for assisting in making me feel so welcome!
post #14 of 17 Old 12-08-2009, 03:28 AM
+Crusader+
So now we're all supposed to feel bad because you didn't bother to research the 200+ threads asking the exact same question that you just did ... So instead of doing that you jumped into a thread with an unrelated topic to ask your question .... and we're all supposed to feel bad for not welcoming you properly?
Nothing personal, but get real brother!
post #15 of 17 Old 12-08-2009, 03:32 AM
Albertaaviator
Nothing personal but........... what ever buddy!
12.50 wide tires on a 10" wide wheel WILLY348 Tires & Wheels 13 05-19-2011 07:24 PM
How wide a wheel for 225/75/15 tires? DocJake Tires & Wheels 3 12-19-2009 04:01 PM
13.5 wide tires with 15x12 wheels redcj576 Tires & Wheels 1 12-28-2007 08:20 AM
16''width tires on 10''width wheels ((~JEEP~)) Tires & Wheels 3 12-26-2006 09:33 PM
Wheel Width / Tires DanaT Tires & Wheels 6 12-24-2003 11:38 AM
