Quantcast Tires not balancing well--beads the fix? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Tires not balancing well--beads the fix?
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 04-13-2009, 02:20 PM   #1
Imped
TITS
Imped's Avatar
Hey guys, I just got some 35x12.50x15 KM2s mounted on Cragar soft 8s, all brand new. I'll start at the beginning. I had them balanced at Discount Tire--weights only on the inside lip....that resulted in a steering wheel wobble at 45+ mph, so I went through and checked out everything to eliminate culprits. The tires....so I went back and had the road force balanced. The tires had a strip of weights added to the back of the wheel and the small tire weights remained on the inside lip. The wobble was better but it persisted at the same speed....so I proceeded to try to criss cross the tires from front to back and side to side (front driver went to rear passenger, etc.). This totally fixed the steering wobble but now the "problem" tire/s were in the rear and I could feel them back there. I went back today and explained. They stripped down the tires and started from scratch and re-balanced the tires with standard weights on the outside and inside lips, nothing on the wheel. The problem is the same and I have a slight wobble in the steering again, so obviously this time they didn't 'fix' anything.
SO, I'm thinking about running 8-10oz of beads in each tire now. It just doesn't seem the traditional method of weight-balancing is cutting it. Does this seem rational? Has anyone else had balancing issues that were fixed by beads? I'm assuming that the wheels and tires are ok and not off-center since they are indeed being balanced to "0" on the balancing machines. Any help or input is appreciated.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 04-13-2009, 02:45 PM   #2
gribbles
I really think you just have a bum rim
indyORV
My Jeep
2000 TJ, 100" wb
2007 WK CRD
gribbles is offline   Reply With Quote
Old 04-13-2009, 02:48 PM   #3
Imped
TITS
Imped's Avatar
Come on man, don't break my spirits.
OlllllllO
Float Test Build
IndyORV
Best served cold
Old 04-13-2009, 02:54 PM   #4
AustinTexasXJ
I had the same problem with 31" tires. what it is is Discount tire company its a dumb POS company that doesnt properly know how to balance tires.
you cant balance tires of the center hole, you need to balance it off the lugs which DCT doesnt do.
question there techniques on how they do it, and then tell them to do it right.
also you can request some kind of roller that roll presses the tire some how.
but this is all what the guy from summit told me and now my tires are shake free!
>Dirty Betty 01 XJ< Wrecked.
>Blue Lucy 97 TJ< Sold.
>STACY 99 WJ<Weekend Warrior.
>Austin Cityprofile.< Check it out.
ΜΟΛΩΝ ΛΑΒΕ!
Xbox live Gamer Tag : BMW Alive 01XJ
Former Nightcrew member #266(RIP 01/28/09 - 07/22/09) www.nightcrew.org
JFI member #2
Originally Posted by SplitNail View Post
...The 4.slow sounds like a pissed off butterfly. just my 2 cents. :)
AustinTexasXJ is offline   Reply With Quote
Old 04-13-2009, 02:55 PM   #5
Imped
TITS
Imped's Avatar
Cool man, thanks. I'm just going to make them help me with dropping some beads in.
OlllllllO
Float Test Build
IndyORV
Best served cold
Old 04-13-2009, 03:19 PM   #6
gribbles
I know, but I am dead serious, I have heard a ton of situations where these things wont balance properly, just because the tards at discount say its balanced doesnt mean poop
indyORV
My Jeep
2000 TJ, 100" wb
2007 WK CRD
Old 04-14-2009, 08:02 PM   #7
Imped
TITS
Imped's Avatar
Well, two of the cragars (brand new) were bent. There's the problem.
OlllllllO
Float Test Build
IndyORV
Best served cold
Glock Forum
