Tires for 11" wide wheel. - JeepForum.com
post #1 of 5 Old 02-29-2012, 12:49 PM Thread Starter
Pierre_r
1989 XJ Cherokee
Its for my chevrolet silverado but i hope its ok that i ask here anyways.
I have 4 wheels that is about 15"x11" for it, will a tire that is 12,50 bee ok or should i buy wider tires for them?
Pierre_r is offline
post #2 of 5 Old 02-29-2012, 01:49 PM
Technohead
How about getting narrower wheels? 8" wide wheels are fine for 12.5" wide tires.
-Eric
Technohead is offline
post #3 of 5 Old 02-29-2012, 02:54 PM
steelhead9
11" Rims
I have 33 x 14s mounted on 11 inch rims and they work well together. If you put 12.5s on the 11" rims your rims will always be banging on any rock or curb you go by. Especially if you air your tires down you will have problems with that combination. It depends on where you plan to drive. 14 or 15 inch wide tires suck up a lot of gas on the road, and they are no good in the snow--more like toboggans! Good luck.
steelhead9 is offline
post #4 of 5 Old 03-03-2012, 12:19 PM Thread Starter
Pierre_r
1989 XJ Cherokee
Thanks for the replys, i think will buy 14" wide tires for them.
Pierre_r is offline
post #5 of 5 Old 03-05-2012, 05:19 PM
Eric290
You say ABOUT 11" wide --- how did you measure the width?
If the wheels are 11" from outside edge to outside edge, then you have 10" wide rims. Rim width is measured from the tire mounting bead to the other tire mounting bead. 15x10s are 11" wide outside to outside.
If they are 15x10s, get some 12.5 wide tires.
If the wheels are truly 15x11s, (12" outside to outside), I suggest getting narrower wheels.
Eric290 is offline
Tires & Wheels (Wheel width for 12.50 wide tires) cowboy1107 Tires & Wheels 16 12-21-2011 07:19 PM
12.50 wide tires on a 10" wide wheel WILLY348 Tires & Wheels 13 05-19-2011 06:24 PM
How wide a wheel for 225/75/15 tires? DocJake Tires & Wheels 3 12-19-2009 03:01 PM
Would... (11.50 wide tire on 8" wide wheel) luv2getbig Tires & Wheels 2 07-17-2009 10:02 PM
