Tire width, whats the best - Page 5 - JeepForum.com
post #61 of 66 Old 12-21-2013, 11:43 AM
SLADE
You've said enough.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #62 of 66 Old 12-21-2013, 12:16 PM
wilson1010
Originally Posted by SLADE View Post
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #63 of 66 Old 12-25-2013, 06:41 PM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Originally Posted by wilson1010 View Post
At the same psi and the same vehicle weight, every tire, regardless of size, puts the same area on the pavement. I have no opinion as to whether a wide tire or a narrow tire is better for gas mileage, but the contact area is the same. Just a different shape.
Can't say I can see this. A stock 225/75r16 on a stock Jeep wheel would not have the same contact patch as a 33x14.50-15 on a 12" wide wheel. or a 38x14.50, or a 54" Bogger.
Try those skinny tires in the soft sand. Won't work. If the skinny tire were the ticket, you would see a lot more of em on comp rock crawlers, trail rigs, and desert racers.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #64 of 66 Old 12-25-2013, 07:44 PM
wilson1010
Its not the same patch. Its just the same size patch in square inches. Its physics. You can't escape it. Divide the weight of the vehicle by the psi in the tires and you will know how many square inches of tire is on the ground.
post #65 of 66 Old 12-25-2013, 07:44 PM
biffgnar
biffgnar's Avatar
The difference in contact patch shape makes a difference for different vehicles and uses (even though the overall area is the same).
Romney in 2020!
biffgnar is online now
post #66 of 66 Old 12-30-2013, 10:31 PM
notJoeKing
Backspacing may tell you whether a wheel, regardless of width, will fit over your calipers or hit the inside your fenders; but offset really is the more important figure because of it's use in determining the handling via the scrub radius. Just because most Jeep owners ignore it (and then wonder why their vehicles handle so poorly) does not diminish its importance.
notJoeKing is offline
