Tire Vs. Rim Width - JeepForum.com
post #1 of 14 Old 09-06-2013, 09:24 AM Thread Starter
brian93tj
2009 JK Wrangler
Tire Vs. Rim Width
Hello everybody!
I'm new to jeepin' and I just bought a 2.5"RC lift for my 97 TJ. Once I put that on I want to get some 31's for it. Will my stock rims fit a 10.5" wide tire? The rims are the 'Grizzly' ones 15X7. I remember seeing a thread about tire size to rim size, but can't find it again. Sorry in advance for the troubles.
brian93tj is offline
post #2 of 14 Old 09-06-2013, 09:32 AM
biffgnar
biffgnar's Avatar
You will be fine
Romney in 2020!
biffgnar is online now
post #3 of 14 Old 09-06-2013, 10:19 AM
WXman
Yeah that'll work good. You might have some minor rubbing issues when you have the steering wheel turned completely left or right, but overall you'll be in good shape with that setup.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #4 of 14 Old 09-06-2013, 11:42 AM
Bhamshooter
Originally Posted by brian93tj View Post
Hello everybody!
Yeah, I have factory 15x7 rims with a 31x10.50R15 tire set on mine. And no lift. So you'll be fine.
You could probably put 32s or 33s on if you want, with that amount of lift. A 33x10.50 would look great.
Bhamshooter is offline
post #5 of 14 Old 09-06-2013, 01:01 PM Thread Starter
brian93tj
2009 JK Wrangler
I've been debating on 33's. I had a bronco with 33" Duratrac's and it did great in the sand and mud. I just didn't know if I would have enough clearance for them. Thanks for the tips.
post #6 of 14 Old 09-06-2013, 01:36 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can fit 33s with a 2.5" lift.
What is your gear ratio?
Wheelin98TJ is offline
post #7 of 14 Old 09-08-2013, 04:55 PM
EMSCHIC76
Hello all, need help trying to decide what tires to buy with what size rims... I currently have no lift but plan on either a 3" body or 3.25" suspension lift my '03 wrangler, I would like to buy Mickey Thompson Baja claw Tc 33" 12.50 15, current rims are Dick Cepek 17", I would like the Mickey Thompson classic II I am having problems deciding on the rim size, not sure I understand what I should be looking at on the rim size, do you look at the surface area across the top? how do you determine this?
EMSCHIC76 is offline
post #8 of 14 Old 09-09-2013, 06:03 AM Thread Starter
brian93tj
2009 JK Wrangler
I haven't looked to see if anyone changed it, but I doubt it. So stock 3.07.
post #9 of 14 Old 09-09-2013, 07:42 AM
jp360cj
1977 CJ7
First of all, I would stay away from a 3" body lift.
Not sure exactly what you are asking about the rim size. There is diameter and width. The diameter must be the same as what the tire is designed for. So for 33x12.50x15 you would need a 15" rim. The width of the rim is measured from bead to bead. A 12.5" wide tire needs an 8"to 10" wide wheel usually. Manufacturer websites usually list the recommended rim width on the spec sheet
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #10 of 14 Old 09-09-2013, 08:54 PM
EMSCHIC76
Thank you for your input, I am trying to understand it all.. I guess what I am trying to find out is, what does the off set mean when buying a rim?
post #11 of 14 Old 09-10-2013, 08:07 AM
Wheelin98TJ
JEEP FREAK
3.07 with 33" tires is pretty miserable.
Are you planning on regearing?
post #12 of 14 Old 09-10-2013, 08:20 AM Thread Starter
brian93tj
2009 JK Wrangler
Was thinking about it. I don't know what ratio to use though. I was thinking 3.55?
post #13 of 14 Old 09-10-2013, 09:47 AM
Wheelin98TJ
JEEP FREAK
If you're sticking with 33s, I'd go with 4.10.
Maybe 3.73 if you can find a deal on a set of factory axles already geared with that ratio.
post #14 of 14 Old 09-10-2013, 10:01 AM Thread Starter
brian93tj
2009 JK Wrangler
Thanks for the advice.
rims , size , tires
