Tire sizes that are actually the advertised height. - JeepForum.com
post #1 of 10 Old 01-29-2016, 05:14 PM Thread Starter
737mechanic
Bought my son a 2007 JKU and it has Terra Grappler 285/70R17 which should be about 33" tall according to the size comparison charts I have found but they actually measure about 31. They are worn somewhat but i do not think they would have been 33 when new.
What I would like to know is what brands and sizes are actually 33" tall.
737mechanic is offline
post #2 of 10 Old 01-29-2016, 05:31 PM
UTAH
UTAH's Avatar
The 34x10.5 BFG's on my JK-8 measure out to 33" tall mounted.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #3 of 10 Old 01-29-2016, 05:36 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Wondering why 1/2 inch of ground clearance matters that much ? Nearly all tires measure smaller than their stated diameter, sometime as much as one inch smaller.
CJ7-Tim is offline
post #4 of 10 Old 01-29-2016, 07:12 PM
sketchy
I've seen tire vendors online that list the measured size of the tires (and the wheel width used for the measurement). I can't find one now though. Anyone know who I'm talks nag about?
85 CJ7 258 T5 32x11.50
sketchy is offline
post #5 of 10 Old 01-30-2016, 01:04 PM
LouC
2007 WK
tire rack does
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is online now
post #6 of 10 Old 01-30-2016, 01:21 PM
LouC
2007 WK
http://www.tirerack.com/tires/tires....l=Grabber+AT+2
just click on 'specs'
General and most tires have the same thing on their websites...
http://generaltire.com/tires/light-t...uv/grabber-at2
LouC is online now
post #7 of 10 Old 01-30-2016, 02:47 PM
UTAH
UTAH's Avatar
Keep in mind Tirerack's specs, like most vendors, are provided by the tire companies. So, their "official" specs are just as prone to err on the large side. Having said that, they're a good place to start.
And, even when tire specs are right, there's still a difference between un-mounted and mounted diameters. You can lose another 1/2" to 1" in diameter.
Bill
'97 Land Rover D90
'03 TJ Rubicon
UTAH is offline
post #8 of 10 Old 01-30-2016, 09:30 PM
Charley3
Tire manufacturer specs don't err on the small side. They're correct for tire inflated to max pressure with no load/weight on it (wheel not mounted on vehicle).
Loaded static height mounted on vehicle (what you care about) will be less because you don't have max pressure and you have load/weight on it (wheel mounted on vehicle).
Actual height while rotating will vary according to inflation pressure, load/weight on it, and rpm.
I wish I had a dollar each time this topic comes up.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #9 of 10 Old 02-01-2016, 09:40 AM
mike_dippert
mike_dippert's Avatar
Using the "rotations per mile" spec is the closest I've seen.
A true 35" circle has 576 rotations per mile.
A true 33" circle has 611 rotations per mile.
A true 31" circle has 651 rotations per mile.
The average 33" AT is 638rpm, which equates to a 31.6" diameter.
It doesn't matter though, because that undersized 33 is still a 33, not a 31.
mike_dippert is offline
post #10 of 10 Old 02-05-2016, 06:31 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Virtually all tires run short. It's just the nature of the beast.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
