tire size question - JeepForum.com
post #1 of 4 Old 02-28-2007, 02:53 PM Thread Starter
strykermp5
tire size question
forgive me, but i am not familiar with the tire designations...
i want to put 33" AT's on next time around and am curious as to the designation of such a beast
are they 265??
thanks!
2007 Wrangler Unlimited X
Jeep Green, Black Cragars, Black Windows
Optional Equipment:
M4 (x2)
Sig 226
strykermp5 is offline
post #2 of 4 Old 02-28-2007, 03:02 PM
luckyjeeper
luckyjeeper's Avatar
depends on manufacturer. my nitto terra grapplers are 285/75R16s and measure 32.8" x 11.8"
BFGs are slightly different. check with the manufacturers websites, or just do a search here, there have been many many many many threads on this.
patrick
2007 JK X 2dr. 6spd.
Steel Blue Hardtop
Virescit Vulnere Virtus
luckyjeeper is offline
post #3 of 4 Old 03-01-2007, 11:07 AM Thread Starter
strykermp5
thanks luckyjeeper
Optional Equipment:
M4 (x2)
Sig 226
post #4 of 4 Old 03-01-2007, 12:12 PM
chandlerr
chandlerr's Avatar
It depends on the other numbers, the first number 265 say is how wide the tire is in millimeters, to convert to inches you divide by 25.4, so a 265 should be 10.4 inches wide, the second number is the percentage of sidewall from width, so if 265/75, the sidewall is 265mm*.75 = 198.75mm, then convert to inches by dividing by 25.4, 198.75/25.4 = 7.82 inches. Then to get overall tire diameter, you take the last number which is the diameter of the wheel and add twice the sidewall number, so for 265/75R16, diameter = 16+2*7.82 = 31.6 inches. Just thought I would let you know where it comes from so you aren't ignorant, but here's the easy way to find out the tire size, http://www.redrock4x4.com/tech/tire_calc.php
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs, 37" Iroks (lost to Mexico. RIP Krystal)
2006 Black LJ Rubicon, mostly stock with 33's... soon to change
chandlerr is offline
tire size question jeepkid03 Tires & Wheels 5 03-24-2009 03:06 PM
not sure how to word this question (Metric tire size equivalent for 31" tall tire?) fphipps Tires & Wheels 4 11-16-2008 09:33 PM
Tire Pressure for 33x12.50 and Tire Size Question blackout00 Tires & Wheels 24 05-14-2007 07:54 PM
tire-rim size question mic6 Tires & Wheels 6 11-05-2006 08:13 PM
Tire Size Question ArchAngel78 Tires & Wheels 6 06-15-2005 09:47 PM
