tire size question - JeepForum.com
post #1 of 10 Old 02-27-2012, 09:33 PM Thread Starter
crockpoppa
tire size question
What is the largest tire I can put on my stock TJ...I believe the rim is 15x8...I've been told I can get a 31" 15x10.5 on that rim...is this correct? Before you ask, no, I have no lift.
crockpoppa is offline
post #2 of 10 Old 02-28-2012, 11:12 AM
biffgnar
biffgnar's Avatar
31x10.50x15 will fit fine.
Romney in 2020!
biffgnar is online now
post #3 of 10 Old 02-28-2012, 05:42 PM Thread Starter
crockpoppa
Thanks...I thought it would be ok, but this is my first jeep...so my questions are unlimited
post #4 of 10 Old 03-01-2012, 08:30 PM
BlueRubiconrich
add a poly lift run 32's
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #5 of 10 Old 03-03-2012, 10:55 AM Thread Starter
crockpoppa
I am new to all this...never did any kind of lifting or after market upgrades...I'm not even sure what a poly lift is.
post #6 of 10 Old 03-03-2012, 10:59 AM
RowJ
Originally Posted by crockpoppa View Post
I am new to all this......I'm not even sure what a poly lift is.
You can add 1" spring spacers on top of the coil springs, without changing anything else.... makes room for 32" tires.
Or just do a 1.25" body lift for 32's.
Some options HERE.... and HERE.
Also please read HERE...... and welcome to Jeep Forum!
RJ
RowJ is offline
post #7 of 10 Old 03-03-2012, 07:38 PM Thread Starter
crockpoppa
Thank you for the info and the links...greatly appreciated.
post #8 of 10 Old 03-06-2012, 11:23 AM
Fokkerflyer
Stock wheel might give you some rubbing when you run 31's, when wheel is fully turned. Aftermarket wheels usually have less backspacing which eliminates this problem.
Or do a 2" BB.
Fokkerflyer is offline
post #9 of 10 Old 03-06-2012, 01:31 PM
matthew900
I'm rocking the 31x10.5's stock and the only time I have any rubbing is in the rare case that one of the front tires gets fully stuffed. Even then I only hear it contact for a second and it's never hurt the tires. You should be good to go with the 31x10.5's
matthew900 is offline
post #10 of 10 Old 03-06-2012, 09:43 PM Thread Starter
crockpoppa
Thanks guys...for all the advice and options...I'll let you all know what I go with.
